Somos un grupo de amantes de la velocidad y quisiéramos asesoramiento d como configurar la m50 para alcanzar su máximo en velocidad tenemos Motor 1500w caja m50 d fabrica y batería Nixon de 30A cualquier ayuda se le agradece,Saludos
Has anyone ever found documentation or had success coding their own interface to a votol controller? I’d like to get readings from my EM-150’s on something smaller than a laptop. I’m able to with the Daly BMS and want to build some safety features and logging in to my build. I don’t care if it’s arduino, Pi / Linux, I can work with whatever.
endless-sphere.com
There doesn't seem to be an easy way to program these as the documentation is very bad. Same settings mean different things depending on firmware versions.Just to update on the situation with my Votol EM-150/2, I still haven't got it running right even after tweaking every parameter to recommended settings. I actually can't understand why it's behaving the way it is. It will accelerate normally up to a low speed, after that there will be a whining noise coming from the motor and speed will not increase. While it is whining, turning the throttle further causes current draw to continue to increase up to around 68 amps, with no change in motor RPM. The motor is getting very hot in the process, despite no load on it. Sometimes the motor will continue to spin slowly with no throttle input which is utterly bizarre. Does it sound like my motor is simply incompatible somehow or is the controller faulty?
Hello friend, I'm new to this, and my English is very bad, I just bought a Votol EM-50S, but I don't know anything, I want to program it with a 70v battery, and a 1000w engine, do you think you can help me? I would like to program it for performance, not for running, I need it to work. Thanks for the help.Please try this and feedback, thanks
Thanks for your reply, I tried those settings but unfortunately I think the issue is with the controller because it hasn't changed anything. I tried it with another motor and had the exact same issue, although now it appears the problem is getting worse. When it gets to the point of whining, it will continue delivering around 20 amps with no throttle input. This controller is nothing but an expensive paper weight at this stage, which is unfortunate because I've already gone to the trouble of making a custom mount for it and the supportive wiring. I'd get another one, but after my experience with Siaecosys, I don't want to go through that again. They aren't interested in helping anymore or for me to return the controller at all. Are there any other comparable brands of controllers you could recommend? I was looking at Fardriver but their internals appear to be worse than Votol.There doesn't seem to be an easy way to program these as the documentation is very bad. Same settings mean different things depending on firmware versions.
If you saved your initial settings might be a good idea to try going from there with just setting the proper pole pairs and do an auto learn. If the issue persists next thing would be disableing field weakening.
I have fw 2.32 and for me setting flux weakening value in sport mode to 0, flux weakening compensation to 0 seems to disable it.
Also the overshoot value (right to the high speed) might be worth playing around with.
Also I've seen some notes that putting a speed percentage less than 100% might do disable FW. So might be worth trying.
If the result is the same, might be worth manually adjusting the phase offset and running some tests.
Note that after each setting you must reset. Using calibration mode exposes the reset button that makes the process much faster without needing to reconnect, even if you're using bluetooth.
Hope this helps.
I am sorry to hear that. I have both a votol and a fardriver and as a personal choice I would pick fardriver all day! It's not perfect but it is far easier to setup and get it running properly than the votol. I only got my votol em50-4 due to its dimensions fitting my specific application like a glove, and of course for the very low price. But keep in mind they're both made by Siaecosys and seems that the fardriver phone app keeps only getting worse each update by forcing you to register and bind the controller to your account.Thanks for your reply, I tried those settings but unfortunately I think the issue is with the controller because it hasn't changed anything. I tried it with another motor and had the exact same issue, although now it appears the problem is getting worse. When it gets to the point of whining, it will continue delivering around 20 amps with no throttle input. This controller is nothing but an expensive paper weight at this stage, which is unfortunate because I've already gone to the trouble of making a custom mount for it and the supportive wiring. I'd get another one, but after my experience with Siaecosys, I don't want to go through that again. They aren't interested in helping anymore or for me to return the controller at all. Are there any other comparable brands of controllers you could recommend? I was looking at Fardriver but their internals appear to be worse than Votol.
When you decrease the pole pairs it slows the motor down significantly. I don’t want to slow the motor down i want to bring the speed that is displayed down to match the actual speed of the wheel. What can i change in the controller setup to modify the displayed speed?Amberwolf,
The connectors pictured are from the Em-150 wiring diagram i received. Looking at the setup screen though i think i need to use the ‘Lin’ sensor. As you can see in the attached photo of the setup software, the options are Hal speedometer or One-lin. In the wiring diagram i highlighted the single white wire labled ‘Lin signal’.
Currently, my display does show speed using the Hal
This is the QS-138 motor and in the Votol configuration it has 5 pole pairs. Do you know how many it is supposed to have? Does hall angle affect the displayed speed?
This thread is specifically about this particular controller, right? We are all using the same configuration screens am I right? These are the screens i see. I do not see anything about wheel size or RPMs. I am very surprised this is not a common issue, has everyones speed just been spot on when they plug in the controller?If it has a wheel size (diameter, circumference, etc) you could change it to half of what it is now.
Otherwise, you'd have to change whatever settings it has that are directly related to the speed display portion, if it has any others, and see what they do.
Unfortunately there is not much info provided by the manufacturer for these, so what you see in this thread and others like it here and elsewhere is what there is, beyond the "manual". So if you do find which settings fix the issue you see, please post them here so others will have that info when they need it.![]()
hTengo un 150 que da marcha atrás después de cargar los cochecitos y me vuelve loco. ¿Hay alguna manera de saber si mi firmware podría ser el problema o cómo actualizarlo? Gracias por mantener vivo el hilo.
Ami em 50 ,actualice con el archivo incorrecto y quedó muerta la controladora ,graciasTengo un 150 que da marcha atrás después de cargar los cochecitos y me vuelve loco. ¿Hay alguna manera de saber si mi firmware podría ser el problema o cómo actualizarlo? Gracias por mantener vivo el hilo.
Como puedo encontrar el archivo bin para mi em 50 ,después de una actualización con el archivo incorrecto quedo muerta la controladora ,no me puedo conectar con el controladorHola chicos, acabo de leer el hilo de 51 páginas y veo frustración y excelentes sugerencias. Mi problema no parecía estar cubierto. El software v3 ve mi EM150 como un EM30 y se niega a aceptar nuevas configuraciones. Curiosamente puedo ver algunas configuraciones que sé que ingresé, como el ángulo de fase, pero lamentablemente puedo conectarme, leer las configuraciones pero no puedo escribir ninguna configuración. ¿Alguien conoce alguna forma de restablecer esto? ¿O tal vez se menciona el archivo BIN en la documentación?
4,1 actualizar el programa ECU.
4.1.1 conecte la línea del puerto serie y la computadora superior y el controlador con éxito.
4.1.2 abra el archivo "bin", seleccione el archivo bin y descárguelo. El mensaje "CCC El último dígito de "d" muestra "d", lo que indica que la descarga se realizó correctamente. La línea del puerto serie se divide en los siguientes modelos: em-30 ~ em-150 general, em-200, em-300, California
i have the file from my old votol em100 (no can) SW 2.32 HW 1.13. mid-drive engine 1500W.Does anyone have a ready VOTOL100 programming file for the 1500W motor SW 2.32 HW 1.13
Any update on this problem sir?My votol em30s status in display is overcurrent, i cannot spinning my motor... what happend om my Votol? thanks guys ... ill appreciate it
