check this dear
this one also
Hi, I connected the Votol-EM 150 to the battery and motor
Battry: 35Amper 72volt lead Acide Gel
Motor: 60 volt 5000watt BLSD QS motor 17 inch Rim
Controller: VOTOL EM-150 no can version1
If don't mind. Anyone can give me votol ini file, I don't know what to fill or change value of the default votol settings if possible... Thanks for your cooperation.
I am on duty, mi country fight for freedom with russian bastard's, i don't have free time at all, when i have it a im answer, sorry, just read this topic from first page, all information in it, more then i know.
OK Dear you have to fight for your homeland. But it is much better if you fight your enemy instead of keep online, this may distract you from your mission.New Bitmap Image.jpg
Hello guys, anyone had problem error "overcurrent"?
I have a Votol em100 GTR and suddenly, at morning when twisted the throttle it stopped. It was running ok for days. The ONLY thing different was phase current set 9000 -> 9600.
With multimeter it beeps when I connect probe from Positive/Negative to Blue phase.
Also BLDC Tester shows this (B, b and C slightly on):
br
bro i already replied to you facebook post.. if I'm not wrong.. its your blue phase (mosfets) are faulty..
br
Hello bro, thanks for repply. Yes, there are bad mosfets on blue phase group. Fix is only by repplacing faulty MOS.
I will let some Votol em100 GTR photos here. PS: there are no reference on the mosfets.1000293764.jpg
Just checked Dear. Speed is 32-56-72.
Please guide me how to set 40-70-90.
After full charging of 72v battery, riding after 2-3 km, 3-4 volts drops quickly. How to long run the battery backup.
A fast drop of 3-4v usually indicates a bad cell in the battery.
can anyone explain what dual volt is... i have em50sp and neednto know if capable of 96v
i mean any votol can be set with dual volt or there is a " controller series" able to do dual? like the case of those 96v line that are different from the 72v line due to mosfets
NO. Em50 votol capable safe work with max 21s of battery, 4.2v*21s = 88.2v, due to mosfet limitation (mdp1991)
Hello Can anyone share a link to the WECHAT MINI VOTOL SETUP APP for android... i cant connect to wechat and i have been charged though... says cellphone not linked to any account but that was what i tried to do... thks in advance
i can share in exchane an android app made by myself to have speed volt and temps in my phone...
Hi, everyone I have a EM-50s and I have Fault 80, Hall error it's no motor hall I tested and it's alright, rn I am not using it on a bike instead its a bench for a project at my university, I use a potentiometer to simulate tps and nothing else its connected, also when I cleared the faults with the brown wire everything works perfectly at certain rpm.
Hall fault is due to the throttle hall sensor..
try using another throttle.
The brown wire is a "quick repair" so you can push your bike back home and not intend to ride on it.
I have a tracktron with a votol 100 48v on it. I opened the program and connected the connection to a laptop. They showed up and settings, but the tracktron got stuck on the barking.
Hey Guys, I just read the 51 page thread and I see some frustration and great suggestions. My issue didn't seem to be covered. My EM150 is being seen by v3 software as a EM30 and refuses to accept any new settings. Oddly I can see a few settings I know I entered like the phase angle but sadly I can connect, read the settings but can't write any settings. Is anyone aware of a way to reset this? Or perhaps have the BIN file mentioned in the documentation?
4.1 update ECU program.
4.1.1 connect the serial port line and the upper computer and controller successfully.
4.1.2 open the "bin" file, select the bin file and download it. The prompt "CCC The last digit of "d" shows "d", indicating that the download is successful. Serial port line is divided into the following models: em-30 ~ em-150 general, em-200, em-300, ca
Hi.
I learning this post for find some solution for my EM-150 controller of my moto. Last day just stop working. Can't connect with software, any way.
I think my .bin is corrupted and need replace.
So, looking for .bin for this controller. I think is em-150s with 180A.
Need help
Regards
