Haf
10 µW
I sent you the file. Look at your e-mailHi Haf, can you send me also the em30sp bin file?
Have you a PM.
Thanks
Have you a PM.
Thanks
can you please send it to me , i asked before about EM50S please!!, if you do not have send me EM30 my box is only working with a blink stm32 sample from me... thanks HAF marce002_2005@hotmail.comI sent you the file. Look at your e-mail
yes have original usb cable ...correct driver prolific too.The firmware are the same fron votol 35 till 100.
You need to pay attention to the cable, you put in the firmware WITHOUT CAN comunication. Have you the correct programming cable? Has you try to swap tx/rx pin?
I sent you the EM30SP.bin. Look at your e-mailcan you please send it to me , i asked before about EM50S please!!, if you do not have send me EM30 my box is only working with a blink stm32 sample from me... thanks HAF marce002_2005@hotmail.com
Ok, I have alreade the same logic analyzer, if the mcu not respond, no way.no no my friend.... i im using special tools here like an logic analizer (from saleae) and can be sure that the MCU is not responding... the app send 4 times the initialize strings but no answer from the other side,,,,, i know about the prolific issue but it is not the case .... something is going on with the firmware flash or the BIN is not the correct one
Is not possible, on the software you can select one of each at time. Not togheter.
Can you explain why you need the booth of them?
Sorry but I'm curious![]()
Theoretically yes! But you need to try!I know the software selection between one-lin or hall, is set to the PB9-pin.
What I'm asking is wether the other output pin (PA12), can send hall-signal, when hall_simulate_output is selected in the dropdown for that pin.
EMI is giving lots of corrupted data - I want a accurate speedo/ODO/Trip-meter, but also want the other data (when I get a random good sample).
And yes, I'm buiding a DIY display.
yeah i checked evry box and switched rx/tx. yep i'm italian.Ps: are you Italian?
If you want to build a diy display, you can get all info trough the serial port!
I also work on a diy display, but give the data from serial connection, more stable and if you want, yuo can program the controller directly!
You can find the complete protocol of uart on this forum, thank to fishblood for this!
Ps: I follow the other thread for lin comunication, thanks to you for the explained tosc delay time in the transmission![]()
That's CAN/USB adapter, they all costs around 40ish euros. you dont find them cheaper@sugar0
Check device manager in windows. If it's a Prolific PL2302, you need to load a old driver (the one built-in in windows don't work with fake ones).
By the way you got ripped off with that price - a regular RS232/485 adapter cost less than 10€.
No, this controller is made only by siaecosys.Oh, missed the CAN-part.
Have you tried with a RS232 adapter?
