That's a fair point....no goatheads in my area thankfully!
That being said, another factor for me is that I use Tannus Armor as well. I did have lots of puncture issues on various ebikes over the years. That was mostly solved by using old tubes as tyre liners, then even more solved by using Tannus Armor more recently.
I also recently started adding some Stans no flat in my tubes which has helped a few times. Like you, changing a flat is a non-option for me so I do everything I reasonably can to avoid.
A more frequent source of flats for me is ripped valve stems (from too low pressure) or pinch flats from smashing into sharp edged rocks (again typically with too low pressure) or too much speed for the terrain.
Have you tried running something like tannus armor in combination with an old tube as a tyre insert? Just an idea and something I would try if I had those goatheads.
Cheers
Cheers
