Very cool to see the 1960s style three-speed hub in use. These shift only when coasting as I remember. They were THEE thing before the first 10-speeds came out. How much torque can be put through them I wonder?
I don't know, but I found the reaction arm stamped Shimano 3SC model. It's casing is custom (probably modified by Schwinn?) but the internals are probably the same as the OTS version (333 type, I'd guess), from the bits of info found with google.Very cool to see the 1960s style three-speed hub in use. These shift only when coasting as I remember. They were THEE thing before the first 10-speeds came out. How much torque can be put through them I wonder?
I've been in a similar situation on my TSDZ2 mid drive trying to find the source of a clicking noise for the last few months. It's not very loud. On windy days, the wind drowns the noise out. It's louder going down hill than uphill. Does not happen on a bike stand. Only when under load, i.e. riding, which makes it hard to pin point the source.I took the4 last couple days off work along with my usual days off consecutive with them, because SBC has had a squeak for months, loud enough for me to hear even over my tinnitus and other hearing problems.
It's the kind of squeak that usually indicates broken metal rubbing against other broken metal, but stuff has been happening at work that prevented me from getting time off to do it (the time I did get off last time it was too hot for me to do all this) while it is cool enough to work on it for hours in the middle of the daytime when I can clearly see things.
So in the last two days, I've gone over the whole trike, taking stuff off where necessary to see all of the metal, and can't find any fatigue cracking, broken welds, or broken tubing anywhere. :/ That includes in the bedframe steel that concerned people after I did the keel repair with it, and the keel itself at the point it has twice broken before. Not in the fork, or the headtube, downtube, steerer, clamps, etc. Not in the wheels (rims, spokes, axles, etc).
Because of my hearing I can't tell where the squeak is from; it only happens while riding. No matter how I move the trike around when it's here at home in the yard, pushing, pulling, rolling it on it's side, etc., sittting on it and holding the brake and rocking back and forth or side to side, bouncing up and down on the seat, etc., it doesn't make the noise. :/
So....I dunno.
endless-sphere.com
endless-sphere.com
endless-sphere.com
endless-sphere.com
endless-sphere.com
endless-sphere.com
endless-sphere.com
endless-sphere.com
endless-sphere.com
endless-sphere.com
endless-sphere.com
endless-sphere.com
Once I had what I thought was a cold, after a week I thought I had the flu, and on the third week I was dying. Finally went to the doctor. He diagnosed mycoplasma pneumonia, and prescribed fortunately the right antibiotic. And that cured what was killing me. Though it took like a month to recover from the effects of the pneumonia. I was mid-thirties, which greatly helped.
What I'm trying to say, is with the symptoms you describe you really need to go to the vet, ah doctor.
endless-sphere.com
Mine is similar to yours pictured, scalloped feathered edge orange border, common small tube of glue that comes in the kit.I've never had a patch properly re-stick after it starts to come off, but I have not used the self-adhesive ones, only the glue-on types. I don't know which kind you used. Presently I'm using patches and teh blue glue from Rema.
batteryhookup.com
These are absolute BEAST power modules with Panasonic cells inside. 48.1v 6.4ah 307.84wh. Built for power but at this price you will not find a better deal on batteries that have either never cycled or only cycled a few times. Perfect for solar storage as well. These modules have 52 cells inside. They are rated for 307.81wh and every module we tested has tested around that capacity. The test of the module is in the 3rd photo. Since these were used as backup only they likely have never been cycled. The cells are power cells, Sanyo UR18650WX 1600mah cells manufactured by Panasonic which are 25a rated power cells. This module can push 100a and had a 150a in-line fuse on it (not included). It is just built so well and it is also easy to work with. The circuit board has balancing but the board is not a BMS, it is a BMU which communicates to a main unit so you will have to add your own BMS.
The 2nd photo shows the easy BMS wiring schematic. The copper piece connecting B- to C- will already be removed for you. BL stands for balance leads. BL- is the main negative balance lead. Usually the main negative balance lead wire of a BMS is white or black color. BL1 would be the 1st balance lead after the negative balance lead. All the way up to 13. So a 13s BMS will have 14 balance leads. One for the main negative and 1 for each of the cells in series positive connection. There are large solder balls on the connections already for the balance leads so you only need to use a soldering iron to heat that solder up, place the balance lead wire in the solder, then remove and let it cool. It takes seconds to connect the balance lead wires this way. The main B- and C- connect easily, just add a ring terminal and bolt those wires down. The main positive and negative connections can simply be bolted down with ring terminals as well.
The battery module is 8 lbs.
The bolts that fit the main connections (not included) are M6-1.0 for the negative side and M5x0.8 for the positive side. Recommend 1/2" length. You can find them everywhere, they are very common bolts.
Module size with handle is approximately 13" x 6" x 2.25"
Nominal voltage - 46.8v (3.6v per cell)
Fully charged voltage - 54.6v (4.2v per cell)
Fully discharged voltage - 36.4v (2.8v per cell)
Max continuous charge - 5a (1.25a per cell)
Max continuous discharge - 100a (25a per cell)
These modules are built to the highest standards and you will be able to see first hand what a top notch battery assembly looks like. The balance board even has fused series connections to prevent a possible short caused by the board.
batteryhookup.com
These modules are pretty awesome and unique. They are 12.8v 105ah lifepo4 in 4s1p configuration. They also have compression. You can buy 4 of these, top balance, series connect, then add a 16s BMS to make 51.2v 105ah batteries.
We are not sure what the amp rating is on the laser welded flexible busbar. If you want to use these in low drain applications we would recommend that. Otherwise you would have to weld busbars to the aluminum studs or use a laser welder for higher amp needs. It seems with the current busbars they should be used up to 20 amps. perhaps they can handle more amps but we haven't tested above 20 amps to confirm. The white busbars are a flexible sheet.
Overall great value here as the modules we tested were all above 90% capacity.
We guarantee all cells to arrive balanced.
There is no BMS on this module. The PCB is just used as a flexible busbar to put these in 4s1p configuration.
Module dimensions and weight below:
8.5" tall x 8" wide x 5.5" deep
20.55 lbs
You can get voltage out of the pins.
The pin connector is 2.5" wide and 3/16" tall. There are 2 rows of 25 pins for a total of 50 pins. The best way to make a connections would likely be to the pins. The 20 pins (2 rows x 10 pins) on each side are the main + and -. The balance lead pins are in the center. You likely could solder the rows of pins to make your main connections. Or if you can find the male connector. We don't know the name of the pin and you would have to use the photos and measurements provided.
The cells also have cooling pad insulation. We recommend keeping these modules in the current 4s configuration however if you wanted to recover the cells it is simple but the connections are laser welded and not bolted
Yeah, those are way better deals especially because of free shipping...I'll have to see if they have any large-format-cell packs like that.
INR18650M29 LG Chem 48V 62.7Ah 2.99kWh BMZ Module
Original price was: $300.00. Current price is: $200.00.
Price per kWh: $100/kWh $66/kWh!!
Years: 2020
Shipping: Free Ground Shipping
Warranty: 6 Months, Extendable
INR18650M29 LG Chem 48V 62.7Ah 2.99kWh BMZ Module quantity
A 48V module made out of INR18650M29 LG Chem cells. The 13S configuration offers an ideal 48V battery pack. The cooling plate is sandwiched between 2 modules. One or both sides of the module that meet the cooling plate have no cover, instead, there is a thermal transfer pad that comes off. So the module you receive may or may not have the plastic cover over the busbars and the thermal pad could be missing as well. Cooling plate listing coming soon.
The last 4 pictures show the best place to make a BMS voltage tap connection. You could solder on the BMS voltage taps to the busbar as shown in the 9th picture. The busbar is made of solid nickel and is extremely easy to solder. There is some glue in that area, but it was easily scraped away with a razor blade. The scraping and soldering took less than 30 seconds if you have all the tools in front of you.
The BMS is under the cover with the large sticker. The BMS takes power from the battery pack it is monitoring to power itself. We unplugged the ribbon cable and plugged it back in and a Green light turned on for about one minute and turned off. The BMS wakes up but does NOT balance and is NOT a working BMS. We monitored the BMS closely and it does not drain the battery after a long period of inactivity. The Sleep mode does not use much energy. If you plan on storing this battery for any length of time over a few months, we recommend unplugging the BMS so it does not drain your battery, shorter durations are of no consequence.
Nominal Module Energy: 2.99kWh
Nominal Module Capacity: 62.7Ah
Nominal Cell Capacity: 2.85Ah
Module Configuration: 13s22p
Max Module Voltage: 54.6V
Nominal Module Voltage: 47.7V
Min Module Voltage: 32.5V
Max Cell Voltage: 4.2V
Nominal Cell Voltage: 3.67V
Min Cell Voltage: 2.5V
Length: 20 1/2 inches
Width: 11 1/16
Height: 3 inches
Weight: 34.5lb
Length with cooling plate: 22 inches
Height with brackets: 3 9/16
Weight with cooling plate: 44.6lb
Peak Discharge Current: 220A
Nominal Discharge Current: 132A
Nominal Charge Current: 30.25A
Peak Charge Current: 60.5A
A closer look at the two first links above shows the black box battery can only provide 25A, so it's not usable, regardless of it's other specs.
I finally remembered to do this today, though I only had time to insert one down between the lighting pack and the traction pack, and then the other down the other side of the traction pack. The AC cords just run out the back edge of the almost-closed lid of the seatbox, so ther'e some heat leakage that way, but their direct contact with the batteries means most of their heat goes into those to keep them from getting so close to freezing.I keep meaning to dig out a couple of old terrarium heating mats to stick on either side of the pack that can be plugged into the wall for overnight warming, but every year I forget about it after it gets warm, and while it's cold I'm usually trying to get other stuff done that I can't do when it's hot out there.
