My 2 cents - Lubrication is done at the microscopic level. Anything that flakes off was too much to start with..... (The guys that race bikes in world class events wax their chains. I got to think they've done a ton of research.)
I started waxing 3 years ago after seeing this video
Long post deleted....
Trying for less wear and longer service intervals, not really a cleaner chain. That's just a nice by-product. I'm at 280 miles on my first waxed chain. Still shifts nicer and runs quieter than chains I used to lube every 100 miles or so. I'll see how things end up on this latest road trip. I'm hoping for 500 miles between waxing but that's just something to aim for. Not sure how realistic it is.just to have a little cleaner chain.
OK, so don't, if you don't see the gains vs the effort then don't. The effort vs the reward for doing anything a certain way depends on the person and any person's reasons will be different. The clean chain for me is a side benefit, I don't both with much of the faffy steps that racers do, I do it for three reasons.Crazy, but your method of waxing just ONE chain takes more time than I have spent on all my chain maintenance for multiple bikes for a year! And all mine run smooth, shift perfectly an are clean... enough. For many of us that just isn't very important. It isn't us just saying we don't want to go through all that phaff as you say. We really DON'T want to go through all that phaff just to have a little cleaner chain.
It isn't just the less wear and cleaner it's also the drivetrain works better and it lasts way longer. The whole I don't have time crew has never shifted a bike with a fresh waxed chain.Trying for less wear and longer service intervals, not really a cleaner chain. That's just a nice by-product. I'm at 280 miles on my first waxed chain. Still shifts nicer and runs quieter than chains I used to lube every 100 miles or so. I'll see how things end up on this latest road trip. I'm hoping for 500 miles between waxing but that's just something to aim for. Not sure how realistic it is.
Pic of the chain is as-is. I haven't cleaned it since it went on.
Not to belabor earlier parts of the discussion but I am very skeptical about wax extending chain life... and besides, chains are cheap. Also not buying longer service intervals as most recommended rewaxing intervals seem similar to re-lubing intervals. Some of you report longer but that is not standard. And re-lubing takes lie 30 seconds anyway.
There's some pretty good proof on page 1 that it has an impact.
A really good drip lube can have the same effect, but it requires regular re-application to maintain the performance.
So yeah it is a matter of whether you want your bike maintenance done in a lump sum, or the installments plan.
As others have said, that's entirely up to you. Here's the thing though, I'd done it your way for 60 odd years off and on, so I know which method is superior, and, you guessed it, it's not the one you still use, but it's your time and money to do with as you please.Crazy, but your method of waxing just ONE chain takes more time than I have spent on all my chain maintenance for multiple bikes for a year! And all mine run smooth, shift perfectly an are clean... enough. For many of us that just isn't very important. It isn't us just saying we don't want to go through all that phaff as you say. We really DON'T want to go through all that phaff just to have a little cleaner chain.
Yeah, but that's not a fair comparison. Even though some of you guys go further the recommended waxing intervals I see are like 150 miles. That is the same installment plan as lube, only with much higher payments. IDK, maybe I need to go all Chalo on you guys.![]()
Good tip, thanks!One last trick, for the home waxer, there's usually a small amount of dirty wax that settles at the bottom of the container. Every so often I remove the solid plug and scrape off the 'dirty bit' at the base leaving the clear wax to be re-used.
Is it a special cord? Shouldn't it be easily rigged?I have an ultrasonic cleaner, but I have misplaced the cord (!!). I never found I could get it as clean as the videos, no matter what solvent I was using. So this time starting with a new chain using several different degreasing protocols.
As far as chain life goes, the Zero Friction dude says that the SRAM 12 speed chains are the longest lasting.
Personally I like to buy the 7-8 speed chains, as they seem the best value for money. Chains are one thing but sprockets and chain wheels are another. If I spend more on long lasting chain, wax it regularly, will it extend the life of cassettes and chainwheels?
I need to go back and look at his post again. Apparently the 12 speed chains are made of a harder steel, perhaps to compensate for being thinner. I was just thinking that a clean chain and sprocket that doesn't attract grit will last longer. A worn chain will wear the sprocket more, so if the chain wears less, the sprocket will wear less as well. Maybe.Compared to other speeds of chains?
I've never seen anyone measure this. I would guess that sprocket wear gets reduced somewhat, not sure by how much.
I was just too lazy to find another cord, as I wasn't impressed by the results.Is it a special cord? Shouldn't it be easily rigged?
My mistake was starting with a used chain. I've since found the cleaning of my used chain was insufficient, leaving old lube inside the chain (between pins/ rollers), which mixes with the wax and slowly work itself out, causing the excessive blacks I was seeing on the white cloth.
I've bought new chains and Silca Ultimate chain stripper, re-starting my test with straight Gulf Wax.
That's surprising. What model is it? I would think an ultra sonics cleaner will do a much better job than just immersion using the same cleaning solvent.I was just too lazy to find another cord, as I wasn't impressed by the results.
A lot of these cycling "rules of thumb" are fairly arbitrary and I wonder how many have been actually tested.
It is a PS-10A, 80 W, just some cheap one from amazon. I was trying to follow an online protocol and just had mediocre results. Don't remember exactly what solvent I used, I don't think its safe to use hydrocarbon based solvents like white spirits or paint thinner or whatever you call it. I was wondering about using citrus degreaser.That's surprising. What model is it? I would think an ultra sonics cleaner will do a much better job than just immersion using the same cleaning solvent.
