Probably all the things you want are in the terminal. Once you've run save in the terminal once the defaults are ignored. The defaults are there so that if you want to make say 1000 units you don't have to go through a terminal setup procedure.
There are parameters for max power, max battery current and so on... If you type get par it'll give you the relevant list.
One gotcha is that the cube ide only reprograms the program section not the saved data section, so after programming with stlink it will still retain the old saved terminal values unless you erase the entire flash using the st cube programmer or similar. Terminal has an erase command save -d but it can be a bit unreliable for reasons i haven't yet debugged.
I looked at the parameters in the terminal and I still could not figure out why the torque at startup is not what I expected with such a big hub motor and big battery pack. I am still able to prevent the wheel from spinning by just grabbing it. Here are my settings after some adjustments.
@MESC>get
Parameter | Value | Min | Max | Description
adc1 | 715 | 0 | 4096 | Raw ADC throttle
adc1_max | 1700 | 0 | 4096 | ADC1 max val
adc1_min | 800 | 0 | 4096 | ADC1 min val
adc1_pol | 1.000000 | -1.00 | 1.00 | ADC1 polarity
adc2_max | 4095 | 0 | 4096 | ADC2 max val
adc2_min | 800 | 0 | 4096 | ADC2 min val
adc2_pol | 1.000000 | -1.00 | 1.00 | ADC2 polarity
can_adc | 0 | 0 | 254 | CAN ADC ID 0=disabled
ehz | -0.177025 | -inf | inf | Motor electrical hz
error | 0 | 0 | 429496729| System errors now
error_all | 0 | 0 | 429496729| All errors encountered
FOC_Advance | 0.000000 | -10.00 | 10.00 | FOC advance, proportion of 1 PWM cycle
FOC_angle | 8189 | 0 | 65535 | FOC angle now
FOC_curr_BW | 10000.000000 | 200.00 | 10000.00 | Current Controller Bandwidth
FOC_enc_ang | 25000 | 0 | 65535 | Encoder angle now
FOC_enc_oset | 25000 | 0 | 65535 | Encoder alignment angle
FOC_enc_pol | 0 | 0 | 1 | Encoder polarity
FOC_enc_PPR | 4096 | 0 | 65535 | Encoder ABI PPR
FOC_flux_gain | 1.272792 | 0.00 | 100.00 | Flux linkage gain
FOC_flux_nlin | 5000.000000 | 0.00 | 10000.00 | Flux centering gain
FOC_fpwm | 20000.000000 | 0.00 | 100000.00| PWM frequency
FOC_fw_ehz | 0.000000 | 0.00 | 6000.00 | max eHz under field weakenning
FOC_hall_array_ok | 1 | 0 | 1 | Hall array OK flag (set to 0 to restart live hall cal process)
FOC_hall_iir | 0.950000 | 0.00 | 1.00 | Decay constant for hall preload (0-1.0)
FOC_hall_Vt | 2.000000 | 0.00 | 100.00 | Hall transition voltage
FOC_hfi_eHz | 0.000000 | 0.00 | 2000.00 | HFI Max Frequency
FOC_hfi_type | 0 | 0 | 3 | HFI type [0=None, 1=45deg, 2=d axis]
FOC_hfi_volt | 1.000000 | 0.00 | 50.00 | HFI voltage
FOC_Max_Mod | 0.950000 | 0.10 | 1.12 | Max modulation index; typically 0.95, can over modulate to 1.12
FOC_obs_type | 1 | 0 | 4 | Observer type, 0=None, 1=MXLLambda, 2MXL, 3=OrtegaOrig, 4=PLL
FOC_ol_step | 0 | 0 | 6000 | Angle per PWM period openloop (65535 per erev)
FOC_ortega_gain | 1000000.000000 | 1.00 | 100000000| Ortega gain, typically 1M
Hall_flux | Array[12] | -10.00 | 10.00 | hall start table
id | -0.014807 | -inf | inf | Phase Idq_d smoothed
input_opt | 25 | 0 | 128 | Inputs [1=ADC1 2=ADC2 4=PPM 8=UART 16=Killswitch 32=CANADC1 64=CANADC2 128=ADC12DIFF]
iq | -0.010642 | -inf | inf | Phase Idq_q smoothed
iqreq | 0.000000 | -4096.00 | 4096.00 | mtr[0].FOC.Idq_req.q
meas_cl_curr | 8.500000 | 0.50 | 100.00 | Measuring q closed loop current
meas_curr | 20.000000 | 0.50 | 100.00 | Measuring current
meas_volt | 4.000000 | 0.50 | 100.00 | Measuring voltage
node_id | 0 | 1 | 254 | Node ID
opt_app_type | 0 | 0 | 3 | App type, 0=none, 1=Vehicle, 2,3 = undefined
opt_circ_lim | 2 | 0 | 2 | Circle limiter [0=OFF, 1=ON, 2=ON Vd]
opt_cont_type | 0 | 0 | 4 | Cont type: 0=Torque, 1=Speed, 2=Duty, 3=Position, 4=Measuring, 5=Handbrake
opt_fw | 2 | 0 | 2 | Field weakening [0=OFF, 1=ON, 2=ON V2]
opt_hall_start | true | false | true | Use hall start
opt_lr_obs | false | false | true | Use LR observer
opt_motor_temp | false | false | true | Motor has temperature sensor
opt_mtpa | 0 | 0 | 3 | MTPA type = 0=none, 1=setpoint, 2=magnitude, 3=iq
opt_phase_bal | false | false | true | Use highhopes phase balancing
opt_pwm_type | 0 | 0 | 3 | Modulator [0=SVPWM, 1=sinusoidal, 2=Bottom clamp, 3=Sin/bottom combo]
par_dir | 1 | 0 | 1 | Motor direction
par_flux | 0.016200 | 0.00 | 100.00 | Flux linkage
par_fw_curr | 0.000000 | 0.00 | 300.00 | Max field weakenning current
par_i_max | 90.000000 | 0.00 | 1000.00 | Max motor current
par_i_min | -10.000000 | -1000.00 | 0.00 | Min motor current
par_i_park | 0.000000 | 0.00 | 300.00 | Max current for handbrake
par_ibat_max | 800.000000 | 0.00 | 1000.00 | Max battery current power
par_ld | 0.000025 | 0.00 | 10.00 | Phase inductance
par_lq | 0.000025 | 0.00 | 10.00 | Phase inductance
par_motor_sensor | 0 | 0 | 30 | 0=SL, 1=Hall, 2=OL, 3=ABSENC, 4=INC_ENC, 5=HFI
par_p_max | 12000.000000 | 0.00 | 50000.00 | Max power
par_pp | 16 | 0 | 255 | Motor pole pairs
par_r | 0.172000 | 0.00 | 10.00 | Phase resistance
par_rpm_max | 100 | 0 | 300000 | Max RPM
par_SL_sensor | 0 | 0 | 30 | 0=OL, 1=Hall, 2=PWMENC, 3=HFI
password | | Password for SU
safe_count | 100 | 0 | 1000 | Live count before allowing throttle
safe_start | 100 | 0 | 1000 | Countdown before allowing throttle
speed_ki | 0.100000 | 0.00 | 6000000.0| amps/Hz integral gain
speed_kp | 0.500000 | 0.00 | 6000000.0| amps/Hz proportional gain
speed_req | 0.000000 | 0.00 | 5000.00 | Hz
TMOS | 227.990799 | 0.00 | 4096.00 | MOSFET temp, kelvin
TMOT | 179.206314 | 0.00 | 4096.00 | Motor temp, kelvin
uart_dreq | 0.000000 | -1000.00 | 1000.00 | Uart input
uart_req | 0.000000 | -1000.00 | 1000.00 | Uart input
vbus | 39.845676 | 0.00 | inf | Read input voltage
Vd | 0.112388 | -4096.00 | 4096.00 | FOC_Vdq_d
Vq | -0.105363 | -4096.00 | 4096.00 | FOC_Vdq_q
Anything that could be wrong in my setup?
