Knowledgebase development fundraiser for 2026
We're 6% closer to the goal this week. Not bad.
Keep it coming!
What increase in user input of content is expected from these upgrades, and how do you measure success of this portion of the project funding and enhancements, from the perspective of adding additional content. I reviewed the kb before donating, but was really disappointed to see little or no progress since I pasted some stuff in last year.
If, for instance, after implementing these enhancements, you see no measurable increase in content, do you continue to invest, or take it off life support?
Are there statistics on how many times the kb has been accessed since the project went live, how many time content was added or edited, by user, etc.? Anything to show users will/may increase participation or content will increase?
I guess I understand in investing in a nice bookshelf, but in the end, I’m mostly interested in the books. Right now there’s only a pamphlet or two at most.
Donating only takes 2 or 3 clicks so it’s really easy, and it’s easier to donate money than time.
I think improving the editor interface 2x could significantly improve the chances that people will contribute.
The existing editor happens to have annoying behavior around features ES article writers want to use, and we found out that's a problem after the fact.
This is also the cheapest part of the job we're looking to do, since i already paid for the new editor integration on another software i'm building. ES is just paying for a graft.
I think article editors getting notifications about comments is about as impactful.
Otherwise they are completely missing those comments with the current design. So effectively, they don't work.
If we had a fluffy budget, we'd design a public high score table for editors, too.
If the tool works very well for the job, but nobody will use it, it doesn't make sense to fund it further.
The performance optimizations are already done so, unlike wikimedia, there is no technical/cost reason to pull it from the site.
The worst case scenario is that it's a slow grower. The best case is that we end up with something awesome.
I didn't build any metric collection into it during the last round to know. But even if i did, bots might skew them anyway.
I get it.
I want to build a fully custom, high durability bookshelf before we start loading it up, and it turns out we needed more for materials.
We've had 3 off-the-shelf bookshelves collapse on us before. That turned out to be a waste of time and resources.
Have you looked into monetization? Like small ads or maybe sponsorships?
Not yet.
The owner of the site doesn't like ads and neither do i. That's a last resort.
Last time we asked for money, it went better than we expected. So we figured we'd ask again.
In previous posts, i explained why a technicality makes it hard to fundraise from a more general audience.
But it may be possible.
I thought i'd ask the people who would benefit from the software directly first. :)
modern world bulletproof format is md, it is very readable by ai and you can use obsidian to write and organize articles and plenty of renders for web to convert it to html.
also about hardware - i got ryzen ai max 395, it is 2.5k$, small and not crazy fast but can fit big models well
I like md, but don't like the limited range of formatting.
I think you should be able to make something closer to webpages. Or at least a notch above wikipedia-level articles.. without having to learn some language.
The new editor stores in JSON format, which can export to Markdown or HTML.
In the future, i'd like to add an alternate article type for markdown, with a switchable text or WYSIWYG editor, to make the nerds happy too. But while you're at it, why not also accommodate arbitrary files? we already have a windows file explorer on the left..
Obsidian is really cool. I don't use it, but it was an influence.
I will chip in $500. ( therefore the amount to raise is lower )
Donations are steadily trickling in also.
Thanks for your donations! keep it coming, i think we can make it :)
I threw in a bit more to help.
Question; Will content added to the current knowledge base be transferred to the new KB?
In other words, does it make sense to continue adding content to the current KB?
Thanks!
The content transfer can lose some formatting. which i will fix by hand on existing articles.
I don't mind if you continue going, it's my fault that we are upgrading the editor.
Funding? we're getting there!
Thinking ahead a bit;
Louis Rossman's FUTO funds projects smaller than Zeropress, like this one: https://notes.futo.tech/
I believe they could help us fund the work that makes it a standalone open-source application.
I looked at one of their surveys to see if it meets this criteria:
I think it's possible we could proceed to then next stage pretty easily.
We are hitting headwinds. Got some pocket change for us?
We only need ~$1200 to get going :)
ChatGPT told me it was worthwhile (Ai is getting smarter). I’m glad it’s learned to provide the logic behind its assessment:
Is it worthwhile to contribute towards endless sphere’s knowledgebase?
Confidence: Medium-High:
I believe the answer is yes, if your goal is to preserve and improve technical knowledge rather than maximize audience size or recognition. My assessment is based on Endless-Sphere’s stated mission, the existence of its new knowledgebase project, the size and longevity of the forum archive, and its continued reputation among DIY EV builders.
I got a weird message saying my donation was as a guest:
“You weren't logged in to Ko-fi when you made your payment.”
not sure what Ko-fi is.
EDIT; never mind. Same message as last time 🤪
It's moving!
https://ko-fi.com/es_kb_fundraiser
On our end:
We're working on other ES stuff while we wait for this to be fully funded - the backlog is thick.
We will have a little more AI hardware around fall and be able to run a 50% bigger AI model, Deepseek V4 Flash. In early tests, it's notably better than the already good model we are running. For the minor role it will play in the knowledgebase, it will kick ass and feel like a commercial model.
After the round of ES work, we plan to work on AI integration next ( on my dime ), and will donate those features back to the ES version.
Keep it coming and thanks for everyone's donations so far ^_^
Knock knock..
We are stuck at 58% funded for weeks and only have ~$1100 to go.
We'd really like to make this thing a reality for the forum, and have editors who are eager to help build the articles out who are waiting for some time to get started, knowing that we need the substantially better wysiwyg editor, which is by nature time consuming to implement.
Can you chip in so we can complete what they need?
I contributed a little $ to help.
The use of Ai is concerning and I doubt that my next statement is going to go anywhere...
I know some out of work IT folks who might be interested in helping but are a little burnt-out volunteering so I'm reluctant to ask them, and I see from your comments that volunteers have not worked out in the past. They are also _very_ anti-Ai, so there is that hill to climb... Buuut, would you like me to ask them if they would like to help?
Thank you!
What are your concerns with our AI use?
Here's what we are using AI for now and in the near future:
Our dev team has been using AI for sections of code for a few years. The majority of code is still written by hand.
AI assists in writing traffic analytics scripts to help pick off scads of AI scrapers for 6 months now with really good success.
In the knowledgebase software, we plan to use it to:
- provide a search function that beats what google/etc is capable of
- produce <255 character article summaries, using writing guidelines that match the tone of the knowledgebase. Right now, our existing system cuts off the first 255 characters and this results in very bad summaries.
- Light AI writing assistant: it suggests edits for grammar, punctuation, sentence flow, duplicate points, etc. The writer can accept all or parts of the edit using a simple mouse based interface.
These features will be funded by me and sent back to ES to enjoy.
Content wise, the only AI generated content we want is summaries. The article editor is allowed to roll the dice a few times for a better AI generated summary and/or manually edit that output or write their own. Otherwise we are not accepting AI generated content for the body of the articles at this time.
All AI processing is done on a local array of GPUs which has zero data retention or unnecessary data transmission.
We don't have any luck finding programmer volunteers for years. But also, the software is incapable of running standalone.
After the ES version, we'll write a 'stub' that allows anyone to download the repo, install it themselves, and submit pull requests and issues. At this point, it would be easy to make the project 'open source' by all means of the word.
We have a github repo ready to recieve that next version: https://github.com/courtesysoft/zeropress-preview
Luckily, we don't have much problem attracting writers. I'm also interested in writing a lot more, long term.
Howdy. We made it a little further, and thanks for your donations so far, but we're stalled again.
What's unfortunate is that we can't get started programming yet.
The main feature that's critical to develop is 80% of the work, and the last 20% don't make sense to do without that item being done.
To get to 80%, we need another $450. Can you chip in?
64% of the way there thanks to a single, regular donor. 16% away from funding the most important feature.
By the way, while the information in the knowledgebase is still mostly empty while we wait for funds to upgrade the WYSWIYG editor, the few articles in there actually get read despite that.
I actually had to delete a spam comment in one of the articles by a logged in member.
So it looks like we need the comment notification for editors just like i expected. 😅
I second the markdown, currently it's the most robust standard that can be written anywhere and taken anywhere. After tiptap is integrated hopefully markdown should be easy to integrate, seeing as it is directly supported by it, providing conversion to and from JSON: Markdown Introduction | Tiptap Editor Docs
(On a sidenote, I was also glad to see that it includes psueso-markdown shortcuts--https://tiptap.dev/docs/examples/basics/markdown-shortcuts--as that is something I now look for in every editor, it can be really convenient.)
I like that idea... I think AI could take this solution even further. Generative UI. Have an optional AI chatbox where you can ask it to create any diagram or layout, and it'll make the HTML and stick it into the editor as an iframe block, with editable fields. This would probably be the ultimate in rendering flexibility, since AI can make just about any visual thing in HTML. Seems like it's tricky, but eventually doable: Google Search
