I see zero bicycle companies doing a better job of building/designing ebikes than we do on the forum.
Instead i would like to see bike companies make bikes that are easier to electrify. Right now, a lot of designs make that a lot more difficult than it needs to be.
Example, most dual suspension mounting bikes used to have open triangles and straight tubes. New ones are anything but.
A frame like that might have an open triangle but it is far from optimal for street usage.
Seriously considering the money people here spend on components a "designed for hub motor" ebike frame and fork is essentially low hanging fruit.
Speaking of components (controllers, batteries, motors, etc.) it would be good if a person knew, for example, the aerodynamics of the bike before they made those purchases. This because aerodynamics can vary quite a bit when factors like tire diameter, q factor, crank arm length and bottom bracket height are significantly different than usual. One example is the impact of shorter than usual crank length on rider positioning to improve aerodynamics and comfort without hurting power:
Crank length can be used as a tool to improve fit related issues impacting comfort, power, and aerodynamics.
rotorbike.com
"Using shorter crank can improve:
Comfort: A shorter crank length reduces range of motion at the knee (extension and flexion), hips, and low back.
Power: A shorter crank alone will not increase your power output, but it can be used to reduce restriction through the top of the pedal stroke by opening up an impinged hip angle and/or reducing knee flexion. Going back to our definition, if we reduce restriction than power output can increase.
Aerodynamics: Going to a shorter crank will allow you to ride at a lower back angle which minimizes frontal surface area improving aerodynamics."
P.S. Another nice thing I like about short cranks is how their higher rpm potential can help cancel out the effect of a small diameter tire's ratio lowering effect on pedal drivetrain gearing.
