And I forgot to post the trip data. Since I had 5 bags of food to bring home but only one cargo pod (since the other is still replaced with the Vpower pack), I had to make two trips. So the first data includes my to-work commute, then the trip home with my backpack/tools/work stuff plus two 15lb bags of food. The second data is just three 15lb bags (all the other stuff stayed home), but is the same path as the first.
The data was collected as cumulative, becuase I forgot to reset the CA between trips as I had meant to (but it's all on the same batteyr charge anyway).
19m 48s trip time
4.763miles
22.3mph max
14.4mph avg
29.1Wh/mile
2.718Ah
142.14Wh
61.68Amax
59.4Vstart
52.9Vrest
47.4Vmin
3.0% Regen
0.0822Ah Regen
-8.48A peak Regen
39m 23s trip time
9.521miles (4.758)
22.3mph max
14.5mph avg
27.3Wh/mile
5.131Ah (2.413)
268.43Wh (126.29)
61.68Amax
52.9Vstart
52.7Vrest
47.0Vmin
3.2% Regen
0.1687Ah Regen
-8.48A peak Regen
Charge data I've gotta go get off the CA when I am not so wiped out (was doing yard work and moving stuff all day today, and it's HOT out there, 102F peak and still 85F! Got lots more to do tomorrow).
Oh, also, whatever caused me to see nearly double the Regen Amps before, has not happened again, no matter what combination of operation of ebrake and throttle I have tried, at any speed from 0 to 20MPH, and SoC from full down to the above (just past half empty). I thought it was caused by throttling up while holding ebrake, as that's what I thought I saw, but it doesn't happen now, doing that, so I dunno. I really want better braking out of this.
During a break in early afternoon I went to goodwill and the grocery store with a friend, and I got a few things:
Ryobi power driver set, has everything and works, but batteries (NiCD) are pretty worn out. When time permits will pull and test some from the DeWalt packs of sub-Cs I have a box full of somewhere, and replace as needed.
Training wheels for a bike, but spring-type. Never saw this kind before. I am going to put them on CB2 and see if they will help me not fall over while I have to sit and wait in traffic; with the springs they will more easily bend out of the way so will do less holding but they will allow me to turn with them still in-place. Might help act as a kind of stand for the bike, too, but I doubt they can hold up the whole bike's wieght (esp. plus mine).
I'm sure I'll need to replace the wheels, but I have some wheelchair wheels with bearings that should fit on them in place of the existing ones, that can take the kind of wear I will put on them using them on the road, at least for a while (unlike the existing ones).
An interesting motor/reduction gear setup:
It's about 10lbs, maybe less, but is cnc'd aluminum housing, steel gears (straight cut), what might be 6 or 7 to 1 gearing at a guess. Appears to be good bearings, big ring bearing on the front of the output gear, and samll regular bearing on the rear of it's shaft.
Gearing shell is open, and appears unlubricated but probably does have some sort of lube. Motor is 12V and has a 24V brake unit bolted on it's far end, along with a tachometer opto output.
The motor itself is far too weak to drive a bike from, but the reduction gearing may well serve a good purpose with a different motor on there.
Motorcycle helmet snap-on face shields. Both were completely unopened and brand new, one clear one shaded. I will now see if I can find snaps I can attach to my bike helmet to use them, and to the MC helmet (which has a flip-up shield).
Four 50W 12V halogens, by GE, 30-degree spot. They are exactly the same housing shape/size as the 20W I have on the bike right now, incluidng the glass sealed fornt cover.
I tested one in comparison with the 20W below, using ISO1000 mode on the camera (which is supposed to disable the auto-brightness but doesn't, but is still better for comparisons than the regular mode). First is 20W + CFL, then just 20W. Next 50W + CFL, then just 50W. I can CLEARLY see the difference in the room, at least twice as bright (looks like 3 or 4) with the 50W vs the 20W, but it's not really that visible on camera.
