I was an unhappy camper (well, rider) today: My front tube blew out while I was going a hair under 20MPH with traffic to my left at twice that, halfway to work at midday.
If I had never experienced this before I would probably have totally lost control and ended up sideways across traffic, and possibly dead. But it happened on a regular bike going down a very steep hill at 30-40MPH once, many years ago, and I DID lose control then, and that was very unhappy (lost a fair bit of skin).
This time, I was able to partially control the bike, but I coudln't steer properly and I couldn't brake or accelerate because the Slime-filled tube puked it's slick contents out into the tire, which promptly began spinning on the rim--somethign I never have had happen, because Slime has always been able to fill the punctures, and not spew out. (when it couldnt' fill the punctures it was becuase they were at the valve core, and any spewing happened OUTSIDE the wheel).
So I ended up uncontrollably side-drifting between sets of cars next to me, and fortunately they were able to stop or go around. One of the stopped drivers just sped up around me and the other one as soon as he could, but the other driver stayed stopped to see if I was ok, with his flashers going, and only went on after I was up on the sidewalk out of the way.
A quick attempt to pump it up showed it was futile as expected, and I had no spare tube. Nowhere I could get to before work would have a spare, either.
I didnt' really have enough time to go home and then fix the problem and get back to work, or to transfer the battery pack to DayGlo Avenger and ride that to work, so I just continued on to work. I stayed on the sidewalks, since I was limited to about 7-10MPH; above that the wheel would spin in the tire and/or slide around sideways when under motor power, making it uncontrollable. I tried pedalling for some stretches but the slight rocking of the bike from my body sway during pedaling caused too much sliding, eventually crashing me against some bushes near a bank once.
Almost half an hour later I got to work, and left messages with a couple of friends with trucks that I thought might be available by the time I'd be getting off work after 7pm, and one of htem called back a few hours later, arranging a ride/transport home.
I could've ridden it back home, too, but another two+ miles of riding on the flat tire wasn't going to do it or the rim any favors, so not doing that was high on my list of things to accomplish.
After getting home, I got the wheel off the bike, and the tire/tube off, finding this hole right in the middle of what would be the tread area on the tire as the source of failure. There is no debris in the tire at all, other than Slime, and no holes in either the tread or the Slime protective liner. No sign that the liner might've caused the damage, either; looks like the tube simply failed and blew out.
Pressure was 54PSI a couple days before when I'd checked both front and rear, so it wasnt' too high or low. I've never had a tube blow out this way without some cause, though. I just wish I knew what the cause was.
I had forgotten to write to Slime about the blown-valve-stem tube a few months ago, so I will write to them about both of these tubes, and see if they warranty them. If not, no biggie, but it'd be nice.
In the meantime I have another medium-thickness tube I'll put in. I may also change the tire itself, as I don't like this one in wet conditions--it's REALLY slippery. It also doesn't grip while cornering very well compared to the worn-out Cheng Shin I had on there before.
If there is time tomorrow on Christmas Day, I am probably going to change out the front fork, too, for the one I want to add the disc brake caliper mount to. I'd like to add the mount first, but only if the welder will cooperate (which it didn't last time I wanted to do that).
Speaking of welders, while a friend and I were out picking up the MC tires
http://endless-sphere.com/forums/viewtopic.php?p=507831#p507831
we saw a nice-looking older-model 110VAC Lincoln wire-feed welder at a yard sale for $250. If I thought I could've talked him down to less than half that, I would have seriously wished for the money. But even if it was worth it, $250 was way more than I could afford even if I borrowed it and paid back over several months (more likely for that much would take a couple of years, at the rate things have been going). It looked kinda like this one, but with white panel and black markings:
