About 9 hours of ragged sleep later, after Tiny dragged me out of bed for her breakfast around 10am (with YOgi still snoring beside me), I am awake enough that I got th ebike on the "stand" of pails and started to do the discharge tests, by rubber-banding the thumb throttles to WOT, which uses almost 4.8A or so for unloaded WOT on both wheels at the same time.
The lighting pack test was also started with the battery medic on it, and it's nearly balanced, except the next-to-top cell which is several hundredths below the others.
But it also shakes the bike badly from resonance between the two wheels' unbalanced spots, so I had to slow the front wheel down some (it's the worst due to larger diameter I guess), making the unloaded WOT current only about 3.8A.
THen I remembered I needed to pull the pack out of the frame to open the ammocan to get to the balance wires.... **sigh**
Turned off the bike, and after much effort, including haivng to loosen the front derailer and remove the chainring crank, becuase I'm so uncoordinated I can't lift and twist and pull the pack out around it, or on the left side either :? , I got the pack out and opened up.
At this point the dogs were pretty bored, as it took a while to get that off there.
Checked balance with the Maxpro 6-cell checker, but it only reads 5 cells no matter what I hook it up to. Dunno what's wrong with it but it's probably the first or second cell, because when I check the top two cells on their own balance tap it only shows one of them. Despite not showing all the cells, the ones it does show are all well-balanced, at 3.59 or 3.60V, some flickering between the two.
I verified with a multimeter that the balance leads are all ok from cells to contacts.
I pulled the Battery Medic off the lighting pack it's monitoring during that discharge (using the headlight at a little more than 4A), and it does read all the cells via the balance connectors, also at 3.59-3.60V for every cell. The first image actually captured a flicker between 3.59/3.60 for the 3rd cell down.
THat's all at no-load. Then I had brunch while typing most of this. Was taking forever to upload images though now it's going ok (started typing it up almost 2.5 hours ago, but keep getting up to see to the dogs and check on the bike, wash clothes, do other chores I haven't been able to do for the last week+).
The lighting pack test finished, though I forgot to put the wattmeter on it
so dunno what Ah/Wh capacity it has. Guess I'll find out when I recharge it.
I checked in on ti just in time, when the low cells (top two) got down to a hair under 3V under load (2.8V and 2.9V), with the other two at 3V and 3.1V. Turned off the headlight and they sprang up a couple of tenths each.
Hooked up my little Sorenson at max current (~250mA) at 3.3V, and am now individually charging each cell, starting with the lowest. WHen they are all equal there, I will hook up the Accucell6 and do the usual 5A max charging to 16.4V, which is 4.1V/cell.
Now it's running a discharge test on the traction pack, and under load from both wheels and all lighting (including brake and a turn signal flashing), about 4.8A average, all cells are still balanced, down to 3.48V as I sat down to add this to the post, except the cell just below the most positive one is 0.01/0.02V (flickers) below the rest.
At this point it's about 11.5Ah or so, cumulative between charges and discharges and regen and this test, since I last charged the pack fully more than a few days ago. But we'll get another reasonably accurate reading of capacity when I recharge it, since it takes very little more to charge than is actually absorbed, and can be called the same for practical purposes.
Now to go check on it again and do some yard stuff now that it's warm and sunny out there.
