Yeah, CB2 is hardtail too, but since it is such a long bike it actually flexes some so feels like very minimal suspension to me as a rider. However, to the wheel itself, it odesn't make much difference, so I have many more wheel problems than evena regular hardtail bike. It's aired up just above it's minimum right now, at 55PSI. Seems like whenever I go higher than that I blow the stems on the tubes, and I am tempted to run lower but the bike feels yucky when I do.ohzee said:That's one weird looking flat. hope those tires work out well for you. I prob put 30 miles on em. I did like them , but just having a big bouncy tire is much better for my commute especially since I have a hard tail.
I test rode it just now for some laps around the block, and it worked fine, and had better grip on the wet street than the knobby.
Although I need to either beef up my motor phase wires a LOT, or turn down the phase current, becuase I can always smell the wires when I stop if there's no wind.that's awesome also the new controller is working so good for you. I cant wait to use my 18 fet one day.
[/quote]You'd hate to see my electric bill - I am jealous of even your big one. if I lived out there id probably build myself a
man cave in the ground to just use natural cooling. the temps you have to deal with are just crazy. hope your
keeping cool.
Usually, it's a dry heat, and that isn't nearly as bad when you're out in it. But right now it's humid and hot, which makes me feel like I'm back in Texas where it gets sweltering meltering. I do wish I could just dump dirt and rock over the house, and make the lot into a hill instead. Would probably make it so I didn't NEED to heat or cool the house. I'd only need power for charging stuff and lighting, pretty much. And cooking. If this was my house and land, I would be sorely tempted to dig the north portion of the backyard out like a sand pit, and put the resulting stuff over and around the house. I would probably need to reinforce the roof, though. Oh, and I recently found out this house was probably built in 1948, about 20 years older than I thought it was!
I have worked pretty hard to cut the bill down this far, mostly by skimping on power usage wherever it was possible to do so, and still practical. Always turning off lights I'm not using, keeping all the "vampiric" power drains to a minimum by turning off power strips that connect chargers and ac adapters and such, even things like the microwave with its little clock and stuff. Anything at all that eats power, even a trickle, adds up. Back when I started looking for them, I found nearly half a KW of vampiric drains, in dozens of places around the house. Half a KW means 12KWh a day! That is a LOT. Almost half of my current daily usage the past two days.
Hard to believe it could be that much, now, but at the time there were several computers (set to sleep or even hibernate automaticallly), routers/wifi/cablemodem, various "nightlights", clocks, appliances, chargers and ac adapters for things that werent' often used but still always plugged in and drawing power, etc. If it had a wall-wart, it was drawing at least a little power all teh time, in use or not.
You might want to look around for such things you can nuke out of your power usage.
BTW, if you look around, you can find the old X10 stuff from RadioShack at Goodwill and the like, and somteims a bunch of them will be in the little bagged items on the wall, for like two bucks. Iv'e never gotten one that didnt' work, either. Wherever you have a concentration of ac adapters or chargers that arent' in use when you aren't there, just plug a power strip into an X10-controlled outlet unit. Put the master controller unit by your front door. When you leave or go to sleep or whenever you aren't using all those things, press the All Off button and it will automatically turn off all your vampire drains hooked up like this. Then press the All On button when you get back or need to use them. Can save a lot of power (and money).
A less-lazy and slightly more power-efficient way to do this is to just use the power strips without the X10, and go around turning off all the power strips when you leave or aren't using them. But this takes time and more effort, so it usually doens't happen or if people do start doing it, they eventually stop because they feel it isn't worht the effort.
