Hello,
I have a ebike with a 24v 10ah battery but cells are dying. Same battery is not for sell anymore.
I have the possibility of buying a 36v 11,6ah battery. Box is exactly the same with only 1 difference, the power connector in the box that connect to the controler is just 1cm to the left and that is why I cant use this box.
So my idea is: opening the new battery box, change the cells to the 24v old box.
Box size and design is exaclty the same.
Charger is different. 36V battery have a more highr V charger.
My question is, it will work?
Wont damage the 250W motor?
And, the 24V charger, will charge the 36V 11ah cells inside the 24V box?
THank you
THank you
