so you're using the coil or a separate bulk charger. i'm not sure about the coil operation, but think it charges up to your limits set.crea2k said:How exactly do I enter balance charging mode too, as I cant seem to see anything about that in the manual ?.
Allex said:Did a run today, 84Volts at 150 DCAmps and 400A Phase = 12kW, so pretty much maxxed out with locked firmware.
All good!
Unlocked can do about 16-18kW without a sweat, but your Cromotor will!
All good!
crea2k said:Allex said:Did a run today, 84Volts at 150 DCAmps and 400A Phase = 12kW, so pretty much maxxed out with locked firmware.
All good!
How do you get that much and not overheat the motor ?, if I set mine to 70 amps 114 phase it gets to 115 degrees c in less than a mile, then the controller turns the power down.
anttipaa said:I have 120/340 and went to small ski center for uphill riding. Pushed 10.9kw uphill and temps were under 50c. I have changed my timing values. With autodetect temps were much higher. Ambient temp was only 15c.
we should try it out but it also could be the temp is shown correct with NTC10k. hopefully it will be lower with the better sensor.crea2k said:Ah ok thanks, mine works on the NTC10k setting so I presume that's what it is, looks like another motor strip down job, fun fun fun ! lol, will be the 3rd or 4th time it been in bits now.
sure it will work.crea2k said:Will this jb weld high heat be ok for gluing the thermister onto the coils ?, it says it can take 232 C continuous
http://www.ebay.co.uk/itm/JB-High-Heat-Temperature-Resistant-Epoxy-Putty-/131196249814?pt=UK_Body_Shop_Supplies_Paint&hash=item1e8be7e6d6
i always used to use jb weld, but now use permatex. reason: if you ever have to remove it, chipping out jb weld is not fun and more likely to damage windings.crea2k said:Will this jb weld high heat be ok for gluing the thermister onto the coils ?, it says it can take 232 C continuous
madin88 said:we should try it out but it also could be the temp is shown correct with NTC10k. hopefully it will be lower with the better sensor.crea2k said:Ah ok thanks, mine works on the NTC10k setting so I presume that's what it is, looks like another motor strip down job, fun fun fun ! lol, will be the 3rd or 4th time it been in bits now.
i have used Arctic Silver 2k thermal glue.
http://www.arcticsilver.com/arctic_silver_thermal_adhesive.htm
anttipaa said:Allex said:Did a run today, 84Volts at 150 DCAmps and 400A Phase = 12kW, so pretty much maxxed out with locked firmware.
All good!
Do you think it would be powerfull enough for commuter motorcycle build with me0913 motor? Would be nice if they would do 150v controllers.
All good!
crea2k said:Iv noticed in the manual it says "Important! When a charger is connected, do not press the throttle and
(or) the brakes. This may result in equipment damage." , the first time I charged it I unplugged the throttle, when I got back this time I forgot to unplug it, so the ebrake would have been on as it turns it on when my throttle reaches zero. All I know now is the whole thing is totally frozen and I cant seem to do anything with it.
