ridethelightning
- Joined
- Jul 21, 2013
- Messages
- 2,010
this would explain a lot of things.
Adaptto E-Drives Lab said:Allex said:For those who have problems with saving throttle curves, Adaptto are working on this and will release new firmware shortly!
Dear friends,
We've released the new firmware which is already available on the web-site.
-The problem with saving throttle/brake limits is solved.
-Fixed the bug which caused blinking display once switching on the controller with high-voltage battery
-Eliminated custom logo on loading screen (appeared in some cases).
Please download here: http://adaptto.com/Support/
Firmwares with passwords for switching between power profiles are available via email request as usual.
If you'll find any new bugs in these firmwares please contact us via techsupport@adaptto.com with description!
Best regards,
Offroader said:What are your hall wire colors, take a clear close up pic if you can.
You are using the 1st and secondary hall wires together if you say your colors are
Yellow, Green, & white.
Because White is part of the secondary hall wires.
Yellow and green are part of the primary hall wires.
I am going to say for sure you have mixed up your wires here. You should also take a resistance check between pin 4 & 5 and tell us what the ohms is to see if your temp gauge is hooked up correctly.
You will have to do a through check like ccmdr said above to figure out where you went wrong.
I think it should be standard procedure to rotate wheel wheel in the debug mode to check if the halls are working properly before autodetect.
BCTECH said:Offroader said:What are your hall wire colors, take a clear close up pic if you can.
I checked the pin 4 and 5 got 969 ohm, is it good or bad?
Also I double, triple checked the pin assignment is correct between the motor and controller connectors
I am pretty sure resistor in the controller is bad, since I don't get 5v.
next step is how to check the hall sensor or wire from motor side?
brumbrum said:You could try and get one of these....'ebike controller tester'... http://www.ebay.co.uk/itm/24V-36V-4...158538?hash=item2360fead0a:g:NPMAAOSwpRRWmMQa
Just connect the Motor hall wires to this and see if the lights switch off and on.
Mammalian04 said:brumbrum said:You could try and get one of these....'ebike controller tester'... http://www.ebay.co.uk/itm/24V-36V-4...158538?hash=item2360fead0a:g:NPMAAOSwpRRWmMQa
Agree, we all need one of these in our toolbox...
rhinejuice said:Mammalian04 said:brumbrum said:You could try and get one of these....'ebike controller tester'... http://www.ebay.co.uk/itm/24V-36V-4...158538?hash=item2360fead0a:g:NPMAAOSwpRRWmMQa
Do they actually work for that cash? has anyone used one? Im a midi noob would like a magic machine that told me what the F--- went wrong this time!
Jonboy said:Hi all I have a small niggle with my throttle.. I'm running variable regen al works great but at low throttle / slow speed im getting a small amount of braking before the throttle starts. I don't get brake come up on the screen & once rolling, say 5-10mph no problem? Any ideas?
Tried switching regen off to btw
Thanks
Jon
madin88 said:Hey Guys,
since long time i'm planning to get my Votec bike with Max-E registered. Now the bike is fully conform to laws requirements, despite one thing:
ziltoid81 said:Unfortunately i couldnt check that cause my bike is a building site again, but i (and some others i guess) would love to see a thread with your registration.
Wish you the best to succeed.
Maybe you can calibrate the regen brake, so it will apply full regen, even if youre only pulling it a little?
DasDouble said:Jonboy said:Hi all I have a small niggle with my throttle.. I'm running variable regen al works great but at low throttle / slow speed im getting a small amount of braking before the throttle starts. I don't get brake come up on the screen & once rolling, say 5-10mph no problem? Any ideas?
Thanks
Jon
In the settings it says "minimum speed". You have to change from 5mph /kmph to 0. Then it will always start. You´re welcome
bigbore said:Offroader said:bigbore said:I have been using 5ml of ferrofluid in my QS205 from a weeek.
How should they be adjusted both DC and phase currents? I'm trying to reduce motor overheat and at the same time have the max power.
For example I rode for some days with DC Amps = 110 and phase Amps = 320. This way I can reach 130°C after about 4Km wot on flat tarmac road.
Today I changed at DC Amps = 120 and phase Amps = 300. After first ride of about 8km (my half daily commute to work) seems better than before but I need to wait for a night ride with no one on the street
How does the Ferro FLuid seem to be working compared to not having it?
What is your average and top speed when you are WOT on flat tarmac road?
Ferrofluid works.
For now I tried on the beach in deep sand and it worked because covering a distance equal to that which in the past led me the motor around at 130 °C with ferrofluid have reached 108 °C
WOT on flat roads I'm about at 85 Km/h with peak power at 8Kw
Cowardlyduck said:Why not add some magnets to the inside and outside of the controller case, near where the FETs are mounted to the case, then add the Ferro Fluid there. That way there is a better thermal path from the hot FETs to the case.
Do others think it would help, or not make any difference?
Thanks for the suggestion. I might try this if heat becomes a problem for my controller.Allex said:hehe, if you want better thermal conductivity from FETs to the aluminium heatsink then you probably should use ceramic pads...
Yep, I've been doing this since 2011.Mammalian04 said:There are stickers you can place on it that will do the same thing.
