Ohbse
DasDouble said:Allex said:Merlin said:ohhh myyy god.....there comes another Vector/Adaptto Fire *LOL![]()
Yes, just so we are clear here. He should absolutely not use Eaton with his 12s battery. This will destroy the battery, can destroy the controller and worst case there will be a battery fire when the cells gets over charged at 4,6V each!
No, it doesn't. Because I am watching the battery voltage. The current says it is 36 Ampere I have a 12s 15 P battery Samsung 30 Q cell inside. Every single cell is 3.45 ampere hours. That means that I have a bettery with 51 A hours. A current of 36 ampere hours means that it has nearly 0.72c rate. = No fire as as long as it stays under 4.2v
As Allex states, you are misinformed. The 30Q is a 3ah cell, your battery is 45ah. Why on earth did you choose such an ill advised battery configuration? You would have been substantially better off with a 20s9p configuration with the exact same number of cells.
You have built something which *will* catch fire if you leave it unattended or are distracted for even a short period of time, this is insanity. There's a good reason all of the documentation for the controller states power supply voltage must be lower than battery.
