smurphy said:If i change this to custom i can't put in 4,125. It's 4.120 or 4.130
Is this a "unlocked" FW feature ?
Cowardlyduck said:Careful how much you insulate it!atarijedi said:Has anyone here bought or built a case for the Adaptto BMS? Or wrapped it in large heatshrink? I'd like to cover it up as much as possible and I'm wondering what others have done.
[youtube]gn-MSFksN2k[/youtube]
Cheers
Yeah, I think you might be right Allex. At the time I put that video together and up until recently, I still wasn't clear on what actually happened.Allex said:Looks like BS on that BMS fire. Why would it start a fire in the first place while riding the bike? Did he have the balancing active while riding or what?
If the adaptto BMS is not balancing then it basically doing nothing, there is no current running through it whatsoever, this must have been a wiring problem?
It excactly works like that.Altair said:Replying to madin-
Yes, the BMS cannot charge, but the controller does.
Doesn't it works like this?: When in balancing mode, the BMS drains the highest cell until its voltage has been dropped enough, then signals the controller to charge again. When the highest cell again reaches the treshold, the BMS stops the charger and begins again the cycle of draining the highest cell etc...
The result of this is that the battery voltage slowly rises during the balancing, until all the cells are at the maximum balancing voltage.
Last year there was a discussion on this very subject, and the concensus was that the balancing voltage had to be set lower than the Max voltage, so that's why I programmed it that way. But I would certainly like to have an official defenite answer from Adaptto in regards to the workings of the BMS.
Anyway, my battery is in excellent shape (it's a LiFePo4) and I very rarely leave the charger ON until it goes into balancing.
Merlin said:ohhh myyy god.....there comes another Vector/Adaptto Fire *LOL![]()
DasDouble said:Ihave now installed a liddle fan on the cables and have put it outside where it is now 1 degree cold. I am now able to charge it already 12 minutes without the cables becoming too warm.#Sciencebro
Altair said:Thanks madin,
My LiFePo4 battery is a 16S pack of 20AH pouches.
Here is a pic of the bike.
Allex said:Merlin said:ohhh myyy god.....there comes another Vector/Adaptto Fire *LOL![]()
Yes, just so we are clear here. He should absolutely not use Eaton with his 12s battery. This will destroy the battery, can destroy the controller and worst case there will be a battery fire when the cells gets over charged at 4,6V each!
