Offroader said:doctorbass: does this allow you to increase the phase amps any? Did you increase yours after you unlocked your controller?
GmagNeato said:Hey gang hope all is well.
It's been quite a while since I was on. I've put almost 3000 miles on my bike with no real issues to speak of.. until now.
I got caught in a pretty bad rain shower yesterday on the way to work. Had no choice but to press on and try to make it there. After a couple of miles, the motor brought me to a shuddering stop. The screen displays "Protect" when I attempt to apply throttle, and nothing happens. From that point on, the wheel drags constantly as if slight regen is applied , (heavy cogging). It does this even when I turn the controller off. Only if I disconnect one of the phase wires does the cogging stop and the motor turn freely.
Today I opened everything up except the motor, to make sure all was dry and check connections etc. I can't detect any issues in the wiring. The halls appear to be working and moving in sequence on the display H1-H6. I tried a System Reset and then an autodetect. After a few moments, I'm getting Halls e2 error message and it stops. Also, if I attempt to charge the bike through the coil, it doesn't detect a voltage and won't charge. Anyone run across similar symptoms/issues and/or have an idea what could be wrong? What else could I test to try and determine if it's a controller or motor issue? I only have a few months left on the warranty, so if it's the controller I'll need to get it sent out asap.
Greatly appreciate any help you could offer!
spektrolyte said:Hey everyone,
Today I have a problem with my Adaptto Max-E setup.
I charged my bike this morning and went for a ride, no problems at all. I came back and put it on charge just like I did yesterday. However, the rack PSU that feeds power to the coil started to overheat and went into protect mode. It does not do this with only the coil connected, this happens when I add the bike into the circuit. The charging display page shows 'no charge voltage' and when I try to run the bike with the 63% remaining battery the motor does not drive forward, instead just shudders.
Unlike the post above there is no error. The BMS shows the cells are all OK and balancing just like normal, it powers on and goes into ECO mode as normal too. I checked all the wiring, particularly the junction between +ve charge lead and motor phase lead. No visible problems with any connections.
Where do I start testing?
CLIFFSIDE said:How do I choose between a 30A & 70A adaptto charging coil? Do the higher amps refer to faster charge time?
icherouveim said:Good morning,
If you have noises like the following video then something should be wrong with your phase wires.
sometimes the problem is with the connection between motor's phase wires and expansion cable.
Make sure to solder the phase wires with the expansion cable if you use one.
https://youtu.be/es_B6IUdoiw
spektrolyte said:icherouveim said:Good morning,
Yes it appears to be a phase wire problem as it has those symptoms, but on another close inspection nothing is disturbed. There was no impact or power failure whilst riding, the bike was running fine when I switched it off and put it on charge. I can't see anything wrong anywhere. Does anyone know some figures that I could measure on the Cromotor V3 (maybe something like resistance between the phase wires) that could help me narrow down the problem? The only thing I can think of is that the coil is 30A and the charger has a max output of 37A, but having said that I never saw the charging draw anywhere near 30A (more like 15-20A) and it charged ok 3 times before this fault developed.
Lash said:Just posting this here as it might help some, who let their battery get too out of balance (like me!) It was going to take for ever to balance on the adaptto and i dont like how it starts and stops detecting charger -current too low all the time, and then makes the mxus squeak a little each time as its balancing. anyway using tp4056 chip and beefy mobile charger >1 amp I could charge 1 low group through my balance lead. This means i didnt have to tear off my shrink wrap and protective foam layer again!
Check it out if you need a simple balance fixing solution.
[youtube]KUmdCJBQM-Q[/youtube]
Allex said:Nice1 but you dont need to have the charger on to balance. Disconnect it and set appropriate treshold for balancing.
Lash said:Allex said:Nice1 but you dont need to have the charger on to balance. Disconnect it and set appropriate treshold for balancing.
Okay. This is the first I have heard of this method, Im sure I havent read about this in this thread or the various manuals around.
So just to be clear, say I set my balancing to begin at 4.10 and my cell high volatage to 4.15. I then charge as normal using the power supply and charge coil.
Then, sometime soon the top cells will hit 4.15 and the balancing will begin. At this point your saying to disconnect the charger. And say I have a low group at 3.8v it will "magically" charge from taking energy from the other high groups of cells? Just by leaving the adaptto on ... for a long time?
Any info on this would be appreciated, as it seems to not be well understood.
Thanks,
Lash.
