Adaptto E-Drives Lab said:
Dear Boestin,
I am sorry to hear that you've fallen of the bike. Hope everything is fine with you.
Next week we will lauch the new beta-firmware fixing the problem with brakes while pedalling with PAS feature.
All the best!
Everything is OK, thanks for asking
and great to hear that another firmware is about to get released. About the incident: I was pedalling really slow when it happened and was just surprised that the bike actually took off when the brake was pressed.
Anyway, here is a workaround to partially make the brakes work: I forgot what its named, but the option when the throttle has to be turned off completely when the brake is used before you can use the throttle again helps. But the power is to " instant" when the brake lever is released, it has to be smoother if you know what i mean.
Also I opt for a PAS option in the menu where you can do the following:
- Usually there is action happening in the HUB after 3 complete twists from the bracketarm (if you know what I mean). It's nice if this is in the menu.
- change the smoothness of PAS.
- at this moment the PAS works when you pedal forward and backwards. I am not used to it. There should be an option to change the direction, like both or forward and backwards
- add PAS to power profiles Normal and Boost
- PAS is only activated when speed is x or higher.
I have two mini-e's atm and I can do some tests for you guys, with alpha or pre-beta releases.
Keep up the good work!
