Doctorbass
Allex said:Does the UP button work inside the menus? Could it be the button itself or the FLAT cable going from the buttons to the PCB board?
No the up button dont work for all menu.
Doc
ridethelightning said:here is some eaxmples and info on diy charge coils.. i gave up pretty quickly and bought the adaptto one :lol:
http://endless-sphere.com/forums/viewtopic.php?f=6&t=53867&start=200#p859672
http://endless-sphere.com/forums/viewtopic.php?f=6&t=53867&start=250#p989965
Doctorbass said:Allex said:Does the UP button work inside the menus? Could it be the button itself or the FLAT cable going from the buttons to the PCB board?
Doc
GreenRoad said:Hello
One thing i do not understand:
Could the charging coild wire (coil +cap) always be stay connected with the controller?
Or is it better to place the coil+cap at the charging wire of the charger direct, and only connect it in case of charging?
The GND of the charging wire goes to an seperate input of the controller (GND) - is this port also switched by the controller?
Because when the motor drives - there is alway the coil + Cap on the load of the motor?
If the Charging port (GND) is switched that would be no problem for that.
That would also be the solution to use an normal Charger with the Adaptto - in the case the GND is switched.
For that solution it would be no problem to connect the charger to the bat+ / Charging GND - if the software of adaptto would support this solution and switch in case of overcharge only the GND away.
Doctorbass said:btw can someone confirm if this representation is right?
and could add were the lock and unlock area are?
would be great to fully understand the max limit! :wink:
I ahve read that the Max-E get max power at 85V... so with 140A batt current that's 11.9kW
Is the limiting feature is inv proportional between 85 and 90 or 92V.. ?
If someone could ameliorate/correct that graph with all these info it would be great! ( with also the luck and unlock limit)
Doc
crea2k said:To test the hardware put in a sd card, then instead of clicking firmware update click the hardware test, this will let you test all the buttons then.
madin88 said:Nope, you MUST disconnect the coil before you can ride (at least from the phase wire or separate charging lead). From what i know the negative charging lead is normally GND and cannot be switched off due to hardware.
If you do not charge with the coil through one of the phase wires, the controller has no control over the charge. it stops at the voltage the charger is set to.
Jonboy said:Hi Guys, can someone just clear up two things about the Max-e controller, I really do fancy getting one but:
1. Are they available at the moment? If so where from as I struggling getting a response from Adaptto.com site.
2. I'd like to use it along with a 24s pack which i never fully charge, it's usually 99.1v off the charger, once riding it sags a volt or two pretty quick before it plateaus. So I'm guessing that will be OK? I'd hook it to my Cro V3, but I'm sure I've read that at the units upper volt level it's max amps is 70 so circa 7KW would be the most I could safely achieve... Or may be I have the phase and battery amps the wrong way around?Please excuse my nubeness!
Any Help here would be great, I'm beginning to pull my hair out ( whats left :lol: )
Jon
Rodney64 said:Jonboy said:Hi Guys, can someone just clear up two things about the Max-e controller, I really do fancy getting one but:
Jon
24s lipo will work, mine run on 99 volt reduced amps until it sagged a little. My Max-e maximum amps is 126 battery and 236 phase amps. 68 battery amps is for the mini. I had my max.e controller pulling 10.4 kW for short bursts.' I purchased both my controllers from Alex. Just pm him. You should get a response.
yea i generally dont charge past 98v so if i can still get a couple of kw round there that'll probably do and save me some trouble rewiring stuff.Rodney64 said:Yes it will still run on 24s at 500 watt approximately until the voltage drops to 98. I bulk charge and it normally sat on 99 volt. Once I open the throte and got some sag then more or less full power.
Doc
crea2k said:Is this hardware or software related though ?, as if they have changed the hardware side on recent controllers to accept the higher voltage you will end up blowing it up on an older controller. If its just a firmware change fair enough. I thought there was a high voltage cut off though that wouldn't allow you to run above a certain voltage anyway ?.
