itchynackers
One of the many reasons I abandoned andersons altogether. I just use them for low amp, non-critical applications, and after they are used up, I won't buy more.
dumbass said:I've installed at least 50 power Poles now (all 30a) and have yey had one come loose. And I used to ride some pretty rough bike trails. But this in not to say it can't happen. As you have already been asked "are you sure the pins are in correctly?". And be sure the cables aren't under a strain in th first place. If you still have problem Anderson sells a clamp that can be used to hold everything together for you. Cheap butthe shipping as always will kill you.
http://www.powerwerx.com/anderson-powerpoles/accessories/110G21-blok-lok-clamp-2-sets.html
Bob
neptronix said:I know this is gonna sound trolly, but welcome to why i like hobbyking 3mm and 4mm bullets and balance connectors for almost every connection i make on my eBike.
Quite a bit cheaper too.
MadRhino said:I don't know about the 30A ones that you have, but when many genuine 75A powerpoles are assembled with their side slots, there are holes between each where you can lace a zip tie to secure them solidly.
I'm not sure to understand, is that the wire pulling out of the terminal (not properly crimped), or the terminal itself pulling out of the housing (not properly locked)?dumbass said:MadRhino said:I don't know about the 30A ones that you have, but when many genuine 75A powerpoles are assembled with their side slots, there are holes between each where you can lace a zip tie to secure them solidly.
Yes, but his problem isn't the connectors them self coming apart. He's having a problem with the wire with the clip pulling out of the back of the housing.
Bob
boppinbob said:Are 45a Anderson Power Poles beefy enough for the connection that goes into the controller. It's a 72v40a controller and I'm using 4 30c 5s8Ah zippy lipos in series which I know are capable of producing much more that 40a. Or should I be on the safe side and go with a pair of 75 amp Andersons.
