Thats to bad coleasterling, one step back. Perhaps a shoulder bolt/screw then. Maybe with a fiber washer or something,
to get just the right tension. The stuff is like cement, like you said. Thanks for testing it out. :thumb:
I've been thinking again,.. and making two back irons on the cores just seems like unnecessary weight and material.
Plus, we have a 1/4" piece of aluminum between them.
All this makes the motor 68mm wide when done.
The spokes won't clear the rotors, when they come off of the bearing cap flanges.
If it goes back to the iron center ring, then you don't need the bottom irons, and the cores can bolt directly to it,
making the total width much less, and saving weight, and no worries about cracking the lower lips.
They could be bonded along with bolting, but I'd rather not.
Any excess steel anywhere can be drilled out.
If the same thing is done with the rotors, rivet the back irons to the insides, then that can be narrowed too. The
whole thing would be 48mm wide, enough to clear the spokes,(?), and also give more room for a freewheel, which will
be needed as well.
I'll have to draw it into a wheel,.. to see if it will fit,.. something like this.
I haven't really thought about a freewheel yet, and I suppose it will need a disc brake mount as well. Dang. More
problems coming. This is why I like mid drives.
