OEM from what? Which controller? What connector? What torque sensor BB does it use now?If I have an OEM controller that supports a torque sensor bottom bracket, can I use any bottom bracket with the same connector, like with the PAS? Or will I need to use a specific sensor from the OEM?
It's the Aventon Pace 500.3. Swapping the controller is no problem but the BB is the wrong dimensionsOEM from what? Which controller? What connector? What torque sensor BB does it use now?
Without any of that information, it'll be tough to help you find a compatible one.![]()
I don't have the controller or the torque sensor BB yet as the BB has the wrong dimensions, so I am not certain what the connectors look like. Unless you're referring to a dimensional adapter. The new one would be larger than the frame opening so that won't work.Send photo of the BB as there may be an adapter available, seen a few in my searches around the net.
