diver
I need to buy a brush controller for a 24 volt Black and decker mower. I have a project for the motor and not sure how many amp controller i need. Id like to go 36 or 48 volt and 15 amp .. the motor only says 24 volt. here is some specs from B&D site
any help on this will be greatly appreciated.
thanks
attery: 24 Volt, 17-amp hour, sealed lead/acid type deep discharge battery
Cutting Width: 19 inches
Weight: 76 lbs*
Motor: 1200 watt output permanent magnet electric motor
Battery Charge Time: 70% on 3-4 hours/100% overnight
Run Time: Mows up to 1/3 acre home lot on a single charge
Ideal mowing area: An average 1/3 acre lot (buildings, driveway and flowerbeds excluded) equals grass area of 10,000-12,000 square feet.
Height Adjustment: Single lever adjusts all wheels at once
Wheel Size: 7†front/9†rear
Grass Bagger Capacity: 1.5 Bu
Cut Height Range: 1½â€ - 3½â€Â
Includes: Rear bag, mulching plate, safety key
Average Retail Price: $399 - $449
Mower Warranty: Full 2 years
Deck Only Warranty: Lifetime
* Please be aware that our 24 Volt cordless mower weighs 76 lbs and may be difficult to push up steep hills.
View The Manual (PDF)
thanks
Weight: 76 lbs*
