izeman
1 GW
thank you that you took the effort to post. i thought of a longer shock as well. but i will try pumping it up to 300psi and see how it works. i could have change the geometry and raise the lower support of the shock. but decided against it, as it would have changed the geometry. and i have no idea how much the riding changes when steering angle becomes steeper.
today i let the rear frame powder coated. i will get it back next week. i also still have one week to adjust cable lenght of CA, brake signal wire etc ... so it will be a clean build.
i also installed an on/off switch in the battery case, and upgraded my led light. i think i can post some new pictures tomorrow.
can't wait to finish the build - after about 6mo of building and 6more of thinking and engineering.
