recumpence
1 GW
Hey Guys,
In the ever increasing quest for E-bike nirvana, I have been searching far and wide for the "Perfect" rim. I like extra wide, double walled rims that are relatively low profile. Oh, for 24 and 26 inch rims, you can get HUGELY wide "Large Marge" rims. But, nothing much in the way of 20 inch rims and even fewer choices for 16 inch rims (trike front rims). The best rim I had yet found in 20 inch was a Nimbus 44mm wide, double wall unicycle rim (that rim was recommended to me by someone on this forum, no less). However, those are discontinued. After much searching, I finally gave up.
Then it came to me; "Why not contact a rim manufacturer to make me rims to my spec?" So, that's what I did!
After a number of emails back and forth, we came up with a satisfactory rim profile and I ordered a few samples. So, I ordered 47mm wide, double wall 20 inch rims (32 hole, but I can get any hole layout I want) and 39mm wide 16 inch rims!
Once I test these (it will take 4 to 6 weeks to recieve the prototypes), I will evaluate them. If they seem good, and I do not have any reason to assume they won't, I can begin having my own rims made.
So, who is looking for wide rims and what is the assumed market for these? (bear in mind, it was not a huge deal getting prototypes made as I merely chose from existing extrusions they already make, chose the roll pattern (diameter), hole) lightening hole layout or no layout, and spoke hole count).
Matt
Matt
