pxl666 said:Atak_Snajpera said:Buying used factory ebike makes zero sense to me.
dude... for 2400 eur you get COMPLETE EBIKE with speedbox , good suspension , good equipment , good condition (saw them myself) , with motor INSIDE the frame . luckily most of them has battery cycles counter so you can guess it's condition , some of them are 750wh .
not to mention that photon will be more expensive than far superior g510
tu put it simply - at 1400 eur for motor alone i see no sense in this - no matter what ... 800 usd might be tempting
this is simply my point of view - cheers
Pat. said:Hello everybody and best wishes for 2023.
I'm relpatively new here and have read a lot last months and now registered as user.
Name Patrick from The Netherlands. Mountainbiking sinds 1994 and never stopped since.
I've been riding the Photon now for more than 300 km's offroad and it hasn't moved a mm.
Mounted the Photon on a Octane One Prone frhame and fits like a glove.
For wattages the 1900 peak seams a bit high. Havent they mixed it up with the max engine rpm. But the i drive it street legal according to European standards. I drive long tours so batterydrainage must be as low as possible
For those interested in reading the review about it check it out on our website:
https://emtb.tech/reviews/cyc-motor-introduceert-de-photon-drive/
Just select all text and translate with google translate oid. Grammar may be of a bit but then you get the idea.
Thanks for the tips/tricks etc.
I'd agree on the stator size and gearing with the assumption of a desire for, or focus on high speed and/or shear grunt. Like the Bafang Ultra or even the BBSHD can muster (just pour in the watts).1boris said:I dont think you should get your hopes to high on this motor.A good mid drive motor should have a big rotor/stator and a high internal gear ratio.And looking at the motor it does not look like there are space enough for a big motor or a high gear reduction.I think it will be weak and easily overheated.Which is the opposite of the whole point with a mid drive.
ncmired said:I'd agree on the stator size and gearing with the assumption of a desire for, or focus on high speed and/or shear grunt. Like the Bafang Ultra or even the BBSHD can muster (just pour in the watts).1boris said:I dont think you should get your hopes to high on this motor.A good mid drive motor should have a big rotor/stator and a high internal gear ratio.And looking at the motor it does not look like there are space enough for a big motor or a high gear reduction.I think it will be weak and easily overheated.Which is the opposite of the whole point with a mid drive.
But isn't there more than one whole point or say, design optimization to a mid drive? How about for a lighter weight, lower average speed, pedal assist focused (not throttle focused) build?
Maybe what the Tongsheng could have been, if they tried harder?
That's my hope for the Photon - a light(ish) weight, medium power torque sensing mid drive that can self manage short duration higher power burst temperature spikes (self preservation - cut back the power if necessary), and bolted into the frame of my choice.
1boris said:If a mid drive is not goona have strong hill climbing ability without overheating you are better of with a hub motor
tomjasz said:I enjoyed the review. It wasn't presented for peer review. Just an Mtb guy sharing.
1boris said:What actually is SILLY is to think you could have a good mid drive with little copper and low internal gearing
