Pajda
🚴♂️ Mega poster
Asked about Lishen 2170SS and SK one company from China with this answer
This battery has not yet been mass-produced.
BTW, nkon have in stock Samsung INR21700-53G1 (Yes I know, "too litle, too late"- I mean Samsung of course) but still ordered samples for the cycle life. In datasheet they promises similar cycle life as their 50G line.
My bad! The P30B from nkon reached 500 cycles this week at 0.5-5C 100% DoD, but I have failed to edit the HP thread yetAwesome, NKON also got some new molicel P30B, looks like a miracle high power high capacity 18650! I am sure it would be worth testing as well.
There are running two settings with HE cells: 4.15-3.00V (ca 90% DoD) in the first post and 4.20-2.50V (ca 100% DoD) in second post of this thread.Are there any plans to ever switch to testing at 4.2V?
Wow, the Vapcell N40 died too. I wonder if the F60 is going to fail similarly.small update after while
Vapcell F36 cycle life is is rather disappointing, Samsung 53G looks similar so far, both at 100% DoD.
It looks like the N40 and F60 failed pretty early, right?Samsung 48X was tested, you can find results here (Yellow chart) https://endless-sphere.com/sphere/attachments/he_1c_90-_cycle_life_test-capacity-png.338062/ Btw. with settings 4.15-3.00V almost all cells can do 3000 cycles. I will show more in lithium-Ion vs. sodium-Ion competition chart, which is coming soon.
In their defense F60 is still running at 100% DoDIt looks like the N40 and F60 failed pretty early, right?
Btw. info about 3000 cycles in 4.15-3.00V range was released for the first generation of 48X. Second generation 48X2 was released with an "upgraded" datasheet with just only 1500 cycles in the same range...would be nice to have Samsung 48x tested, spec said 3000 cycles
Thanks!Samsung 48X was tested, you can find results here (Yellow chart) https://endless-sphere.com/sphere/attachments/he_1c_90-_cycle_life_test-capacity-png.338062/ Btw. with settings 4.15-3.00V almost all cells can do 3000 cycles. I will show more in lithium-Ion vs. sodium-Ion competition chart, which is coming soon.
