Interesting that the nominal voltage drops on their highest and lowest capacity cells.Kumyang has licenced StoreDot's technology and they have listed some curious new cells on their website:
High Si anodes tend to cause that.21700 7Ah at 3.35V nominal? What chemistry is that?
No sadly.Are these Linshen LR2170SK available in Europe ?
Is it? I was very curious about this particular BAK 58E cell, unfortunately it was not available anywhere. I'll try asking Vapcell again.The BAK 58E, on the other hand, is actually available to purchase in bulk at actually reasonable prices.
Yes: 2500pcs at 2.95$USD each.Is it? I was very curious about this particular BAK 58E cell, unfortunately it was not available anywhere. I'll try asking Vapcell again.
Nice, Vapcell probably already has them too, waiting for a quote.Yes: 2500pcs at 2.95$USD each.
Did I miss them? Nkon says they have them on pre-order with delivery at the earliest 04-06-2025.There is a Tenpower INR18650-35HE listed at nkon for a interesting price. Might worth a test? with 50grams pretty heavy for a 18650.
No, I just found them listed for the first time for pre-order.Did I miss them? Nkon says they have them on pre-order with delivery at the earliest 04-06-2025.
By the way BAK 58E has been stocked in Poland and ordered today.
I’ve got a pair of each in transit and am looking forward to seeing how they perform. Vapcell can be a little optimistic with capacity ratings, “rounding up” datsheet ratings, but their current ratings are usually pretty close (but might be temperature-limited).I noticed that Vapcell recently released their new products
Vapcell N41 @ 4050 mAh in 18650
Vapcell F63 @ 6250 mAh in 21700
These look nice.I noticed that Vapcell recently released their new products
Vapcell N41 @ 4050 mAh in 18650 New Release Highest Capacity Vapcell N41 18650 3.7v 4050mah 10a Li-ion Rechargeable Battery For Flashlight - Buy 18650 4050mah Li-ion Battery highest Capacity Vapcell N41 18650 4050mah 18650 3.7v 4050mah 10a Product on Alibaba.com
Vapcell F63 @ 6250 mAh in 21700 The Highest Capacity 21700 Battery Real Rating Vapcell F63 21700 3.7v 6250mah 12.5a For Power Tools And Flashlight - Buy 21700 3.7v 6250mah 12.5a 21700 Cell 6250mah vapcell 21700 6250mah Battery Product on Alibaba.com
The best low price high energy cells are likely to be the EVE 50E, Samsung 50G, and other similar 21700 cells in this category.Would you consider the EVE 35V as a good energy cell with a reasonable price tag? With 100% DoD the cycle life is reduced, but with 90% which is more reallife usage, the lifespan is fine for most usecases.
Or are there better ones?
Well, if that's the case, EVE 33V, EVE 35V, Samsung 35E, Molicel M35A, BAK NCR18650CG-35E (better electrolyte alternative to the Samsung 35E), Lishen LR1865HB are all great choices, althought I'd pick the newer cells 18650 like the Molicel M35A, EVE 35V and BAK's variant would be your best bet.Ok, I agree for building a new battery from scratch. But replacing defective 18650 cells its easier to stay 18650.
