Hey Dave and thanks for sharing those real world numbers!
-Justin
These results are almost a perfect corroboration for what I've been getting in the lab setup. With the closed hub, the conductivity from casing to ambient was between 4.5-5.5 watts/degree depending on the RPM and fan wind speed. So assuming that the oil does a near perfect job of transmitting heat from stator to casing, then we'd expect the total conductivity from stator to ambient in the oil filled motor to match that number too, as you got here.intoworldsofuncertainty said:Conclusion: Assuming I've worked all this out properly, the addition of oil as a heat transfer medium increased thermal conductivity by a factor of approx 2.5 times.
It's actually quite easy to do. Just lift the wheel off the ground and record your no-load power and wheel speeds from very low throttles up to full throttle. Do that test with and without oil in the hub, and the difference is the power added from the oil fill.So looking forward to seeing what results you come to with proper controlled experimentation. Would be great to see also, how much drag the oil adds to the motor. I personally haven't noticed much, but also haven't done any definitive testing.
-Justin
