Merlin said:you will get alot of dirt too in it ;(
1-2 days ago i saw some pictures how many dust(sand) goes inside...
piwhy said:Merlin said:you will get alot of dirt too in it ;(
I only drive on asphalted road in city or Parisian suburbs, rarely under rain and never under snow and I plan to fix a fine mesh screen on each holes.
That's should be enough to prevent from dirt going inside, isn't it ? And if that's not enough I can add a filter on air pipes...
John in CR said:The tail rotor doesn't work very well once there's a fast flow at 90°. That's why it has a tail and rudder. That's also why the tail rotor is outside of the swept area of the main rotor, since the main thrust would render the tail rotor almost useless at low air speeds where it is needed the most for fine control.
Merlin said:totaly confused which way i should go![]()
can someone tell my where i can buy "new" sidecovers for the 3540?
speedmd said:Looks like lots of folks are chomping at the bit for the next posts on the testing to see which ways may be best to explore further.
Open/sealed, wet/dryMe too.
justin_le said:Hey guys, unfortunately I had to put a pause on this testing process just as it was getting interesting due to some prior project commitments with more imminent deadlines. There is a small chance we'll be able to run one of the oil cooled tests this weekend, but otherwise we'll need to put things on hold for a good 5-6 weeks before things can resume.
-Justin
John in CR said:Why do you think you need "new" side covers? If you already have some big holes in the covers, then it should be easy to modify what you have to make it flow air better. Just add a bunch of small exhaust holes at the extreme perimeter that butt up against the rotor ring retaining lip. I say small because that's the only way to get them at the perimeter. Add some blades, though I'd suggest bending them at about 45° instead of the 90° vanes in the pics above. Do the blades right at the leading edge of your existing big holes (assuming that's what you have and they're near the windings) giving you some adjustability from the outside. If you don't have any holes toward the center you can add some intake there too for an even freer air intake.
That will get you some cooling air flow, but you probably should look at controller settings too. What phase and battery current limits are you running?
Great! Look forward to seeing the initial results. A small taste should hopefully help make a more interesting layover.justin_le said:speedmd said:Looks like lots of folks are chomping at the bit for the next posts on the testing to see which ways may be best to explore further.
-Justin
I hope no-one becomes confused and tries CBN (cubic boron nitride) by mistake. CBN is an extremely hard (equal to diamond) abrasive commonly used in high speed steel grinding where diamond will wear away due to the carbon dissolving into the iron at high temperatures.speedmd said:Some source for some various size HBN (hexagonal boron nitride) fine powder samples for increasing oils heat transfer.
nice work. fyi: i realized too late that my bearing were only rated to 100C and the bearing seals failed after too many times hitting 120C (seal removed showing atf in bearing) from here:izeman said:did some testdrive with my oilcooled hs3540 today....at my house windings had reached 98C.
GCinDC said:nice work. fyi: i realized too late that my bearing were only rated to 100C and the bearing seals failed after too many times hitting 120C (seal removed showing atf in bearing) from here:izeman said:did some testdrive with my oilcooled hs3540 today....at my house windings had reached 98C.
Those seem to be the same already installed in my motor. Though I guess mine are not genuine SKFh0tr0d said:GCinDC said:nice work. fyi: i realized too late that my bearing were only rated to 100C and the bearing seals failed after too many times hitting 120C (seal removed showing atf in bearing) from here:izeman said:did some testdrive with my oilcooled hs3540 today....at my house windings had reached 98C.
Great bearings and cheap!
http://www.ebay.co.uk/itm/E26203ZZC3-SKF-Energy-Efficient-Bearings-17x40x12mm-E2-6203-ZZ-C3-SKF-/161008943959?pt=LH_DefaultDomain_3&hash=item257ce18357
i have thought about it...rui_fujino said:I know some people must have thought about this but has anyone attempted to make a use of peltier?
I think instead of trying to use ambient temperature to cool hub motor, we should be using something which is cold to cool hub motor.
since the hub is designed to spin, we can use the peltier to cool down inside the hub and some sort of air vent to release the hot air outside.
any thoughts?
additional video:
[youtube]3x-wxLEfLEQ[/youtube]
