newbie electric rider
Wow, I have been absent for a month!! Enjoying the waning days of summer. Very nice job Beagle!!!!
dirty_d said:id get this http://www.out2win.com/catalog/img/rlv0702.gif and chop the sprocket off of it and weld your original unite sprocket in the center of it.
TylerDurden said:..."Consider a machine intended for operation up to 100 Hz, 200 V three-phase RMS, 100 N-m rated torque, 6 poles, 2000 RPM base speed, 21 kW output, and a 3:1 field weakening range. If the stator winding taps are rearranged to provide a 66 V rating (low-voltage delta connection) instead, and a source capable of delivering 200 V at 300 Hz is available, this same machine can be re-rated for 300 Hz, 200 V, 100 N-m, 6000 RPM, and 63 kW output power without field weakening ratings violations."
This is not simple overvolting. If that's the only way you can understand it, fine. But trying to convince the rest of the world that it is simple overvolting is pathetic.
The re-rating method applies to PM motors too. Dumbing it down to your level and calling it "overvolting" is a gross oversimplification of one of the most significant developments in electric motor engineering.safe said:As I said before the case you are pointing to is AC power and not DC power.
TylerDurden said:re-rating = 300%+ performance
Toorbough ULL-Zeveigh said:hmmm...
According to this weather map, there seems to be a high pressure system blowing a lot of hot air out of Missoora.
(as indicated by the arrow pointing to safe's house)
KEE-ding!
:lol:
Toorbough ULL-Zeveigh said:According to this weather map, there seems to be a high pressure system blowing a lot of hot air out of Missoora. (as indicated by the arrow pointing to safe's house)
Beagle123 said:Att: Thanks, I love the aluminum look too. I'm trying to figure out if I can just leave it unpainted. I guess it would oxidize. I wonder what it would look like. I guess we'll find out.[/size]
Aluminium oxide is responsible for metallic aluminium's resistance to weathering. Metallic aluminium is very reactive with atmospheric oxygen, and a thin passivation layer of alumina quickly forms on any exposed aluminium surface. This layer protects the metal from further oxidation.
Miles said:I would use one of these: http://www.whiteind.com/ENO-free-specs.html
The 22t version has weight-saving slots milled into it that you could easily bolt a custom adaptor to #219 spec to. That was my solution to the freewheeling cranks problem... :wink:![]()
