Bracket For Shocks Welded, Back Forks Attached to Battery Box
First of all, thanks safe, and thanks for all your help. You've helped me a great deal with my project, including giving me the inspiration to tackle framebuilding.
The brackets that hold the shocks look really good. Again I over-engineered it. They're 3/16 in aluminum with welds everywhere.
I'm using a hinge setup for the pivot point between the body of the bike and the back end. Its just a 1/2 X 7 1/2 inch bolt that connects the sides of the battery box together. The back end has an aluminum tube that the bolt fits into perfectly. There's a steel washer on each side. When the bolt is tightened it make the back end fit snugly between the washers. There's a bit of friction, but not much.
I welded little squares of a3/16 inch aluminum over the spots where the bolts penetrate so there's no chance of this point breaking. This is a critical spot. THe total thickness of the metal is 3/8 inch. Should be fine.
I spent about two hours checking and re-checking the locations of the holes to attach the back of the battery box. It was difficult because there was no way to put the forks in place and mark for holes because they would be covered by the tabs on the back of the battery box. I had to drill a hole on one side, then align the opposite hole buy using a framing square to transfer the point across to the other side. When all was done, the back of the forks were off by perhaps 1/8th of an inch. Actually I think that's pretty good because every minute fraction you're off on the hinge end is magnified by about 3 times on the back. I did a little bit of filing on the holes to even it out, but I think its fine. In fact, I wouldn't be suprised if it was perfect when the wheel is put in.
