I am limiting the motor phase current to 135 amps and I see the motor getting hot relatively quick. The seller told me this is a 2000W motor and the max motor phase current should be 80A.
Well, if you're running 135A thru something that only takes 80A, I'd expect it to get hot pretty quick.
That's almost 1.7x it's design intent. (assuming that this is actually a real manufacturer specification, and is actually for phase amps, vs average battery current (which is a more common spec to be given)).
What's the actual continuous phase amps during an actual ride when it's getting hot? (if you said, I missed it)
If you're only peaking those levels every so often it wouldn't be such a big deal, but doing it a lot or for more than a few seconds at a time is probably going to build up heat pretty quick.
I don't know how the VESC does that test / mode, so I can't say why it is doing what it's doing there.
But...any test that doesn't have a physical load on the motor to create the current demand by it seems that it would not be a real-world type of test, and it's results might not be applicable to actual usage. I don't know enough about how such a test might actually be done without a physical load , by only the controller, to even guess.
The main things I've seen heat up motors that shouldn't for the given power level are running them with poorly-tuned controllers vs the motor design, and running them under loads that the kV they have doesn't support for the speed they're being driven at.
The former is certainly fixable with a VESC, although I have no experience at all with tuning one.
The latter just means that if the motor's loaded RPM at the given battery voltage and controller-output-level is too low, compared to the RPM it would have unloaded in the same inputs, there won't be enough BEMF to counter the current into the motor, and it will heat up more than it should. (you probably already know all this, but if not, play with the ebikes.ca simulator with any of the thermally-modelled motors in various setups to force this to happen, and you can see it in the charted results).
This specific example isn't directly applicable to an FOC contorller as they modulate torque, not speed, but it should get the idea across (I can't presently think how to state an example for an FOC, but there is a way): For instance, if the motor's unloaded speed at say, 50% throttle, is 500RPM, but loaded down it drops to 100RPM at 50% throttle, the current will be say, 5x higher than it "should" be. (realistically loaded is usually around 80% of unloaded RPM, so it *should* be around 400RPM, so current is really only 4x higher than it should be). But that means it heats up proportionally faster than it would if it were able to run at the speed it should.
I'm not sure if that makes any sense...I'm too tired to continue the thought, though.
