While I am waiting the arrival of some of the LighteningRods side sheets I ordered. I have been working on the drive pulleys. So far, I have managed to mould and resin cast the 14 to 18T slip on adapter, seems ok, and fits snugly on the motor. I tapped a 5mm thread in the motor shaft and fastened an end plate on to retain the adapter.
Now I am making a mould to cast a slip on adapter for the big pulley which will be 107T. This will give a slightly improved ratio compared to the original 80/14 pulleys. Until I can test the casting out under load I am not sure if they will stand up to long term use.
I used a slow cure casting resin with aluminium filler. I hope this will give a hard none brittle cast that can resist wear. The tooth profile has come out well with a nice smooth surface which should help to reduce belt wear, especially when compared to the original GNG belt/pulley setup.
My suspicion is that I will finish up having to go for a primary chain drive mod at some stage. I have all the bits and bobs for the chain drive but until I know the belt & pulley is not going to work I don’t want to file off the motor shaft.
![8576531377_6e9494ae05_c.jpg](/sphere/proxy.php?image=http%3A%2F%2Ffarm9.staticflickr.com%2F8091%2F8576531377_6e9494ae05_c.jpg&hash=f631a83c498ceeaab175124d19bbd0d7)
![8576530545_9596351fdf_c.jpg](/sphere/proxy.php?image=http%3A%2F%2Ffarm9.staticflickr.com%2F8513%2F8576530545_9596351fdf_c.jpg&hash=e018d7b454b520e6a24a93f5d89e70a6)
![8577632008_84c2682ca8_c.jpg](/sphere/proxy.php?image=http%3A%2F%2Ffarm9.staticflickr.com%2F8515%2F8577632008_84c2682ca8_c.jpg&hash=fcadb7c1660528dc261e8e477d2f436b)
