simplydata
New-ish here
I used this motor on both a Catrike Road and a Catrike Dumont without any issues. Both have 135 mm dropouts, and without spacers. I did install a larger torque arm for added strength. Also, be careful not to bend the motor cable too close to the axle—the sharp edge can cut through the wire unless the motor axle is kept from rotating.
