Hello,
I need to know the brand to get the right cable/software.
I use pas 0 to 9, because to me, the 0-5 is not well tiered, like if it's not the native pas used to program the controller.
It acts like we are supposed to use 0-9.
So...
1 - PAS and Nb of Turns/Volt
If it's possible, I would like to change values for the 0-9 pas. I would like to reduce torque/power on first pas numbers, to save Ah, and to change the number of turn per volt, if my calculations are good.
I made quick calculations, but I will do more precise ones, if I know I can set this controller..
I understood that the G062 1000w can be adjusted from 6T/V to 8T/V with 52V nominal ( 14S )
My bike has 24" wheels, not commonly used, and I think the controller is actually settled to 6T/V, my top speed is 42km/h with a fully charged battery at 58,8V. The average top speed is more close to 38km/h.
If possible, I would like to make tests at 7 and 8T/V, and change 0-9 pas settings.
I would like less power/torque on first pas values ( 1 to 4 ), and a little more top speed (45 to 50 is a target) at the latest values.
These are the 2 things I would like to do, but...
2 - Battery Level management
If possible, it will be good to be able to change the way the battery level is managed and how it's displayed on screen, without changing cut off value, off course.
When my battery is empty, and the display say 11%, I still can see 2 bars, and it's too much to me, only 1 bar would be more representative.
At the inverse, when I start with a fully charged battery, I can do 20/24 kilometers, before to lose 1 bar, and still can see 97%.
I have seen many other available settings on some controllers, but I would be still very happy to be able to do the first things I described on top ( 1 ).
Sorry for my poor English,
Bye !
