Jamesavery22
- Joined
- Apr 9, 2019
- Messages
- 24
Has anyone ordered cyclone's coaxial eeb kit? Very curious about that setup.
Jamesavery22 said:Has anyone ordered cyclone's coaxial eeb kit? Very curious about that setup.
Skaiwerd said:I’d look closely at the pictures of how that motor mounts to the swing-arm, and the swing-arm to the frame. I’m sure it functions fine but doesn’t seem ideal. I think someone stateside could do better at the design. Single speed on the left keeps your your pedals. I know you know this. Yes no point in this motor then.
Jamesavery22 said:Definitely good with the looks and getting just the swing arm + motor. I've been tempted to ask about their 7.5k motor but not being able to pedal has me very hesitant.
Jamesavery22 said:Skaiwerd said:I’d look closely at the pictures of how that motor mounts to the swing-arm, and the swing-arm to the frame. I’m sure it functions fine but doesn’t seem ideal. I think someone stateside could do better at the design. Single speed on the left keeps your your pedals. I know you know this. Yes no point in this motor then.
I'm honestly curious about what you mean but I don't follow. The way they mount the motor to the frame definitely looks like it could be improved. First thing that drew my eye. Are you saying it should be a deal breaker? If so, I'm curious why?
Jamesavery22 said:Gotcha. Still on the fence even if they had a 7.5kw kit. I emailed and asked if they had one. Either way I need to source an EEB frame in the States and I can't find them anywhere but China. Do I need to wait until one shows up on eBay?
Skaiwerd said:Sorry to confuse.
The motor appears to be mounted in a type of band clamp to me. And the structure/strength of the swing arm is only this piece of bent round shaped metal where the motor is. That metal may be considered sheet metal as it does not look very thick. The mount of swing arm to the frame looked crude and not long enough to be strong enough. The part the bolt goes through. Twisting might occur here if anywhere. Seems like there should be some precision parts in this area. Some or a combination of Plasma cut or water jet or Cnc’d or cast parts. The prices for this stuff is low or reasonable and we’ve gotten use to better. I know it’s a budget bike frame. At some point we’re doing better here figuring it out ourselves.
Jamesavery22 said:Oh. I didn't know they had distributors in the US. Assumed they were completely in China. Whoops. My fault.
Coaxial needs a custom frame, similar to bafang ultra.LexHammer said:Whats the difference between Coaxial and lets say BBSHD motor?
Tommm said:Coaxial needs a custom frame, similar to bafang ultra.LexHammer said:Whats the difference between Coaxial and lets say BBSHD motor?
Or cut up an existing one like this guy.
https://electricbike-blog.com/2018/03/03/choppy-shloppy-build-your-own-ultra-max-specific-frame-and-get-riding-already/
Other difference is power. Coaxial can reliably handle about 3x the peak power as the bafang, it is a genuine 60mph motor. Which means if you want to feed it with enough batteries you would probably want a custom frame anyway.
LexHammer said:What about efficency? Which one will make more range in equal conditions? And reliability? Is the motor of the Sur Ron Coaxial?
.by Jamesavery22 » Apr 24 2019 2:04am
alexmaemur said:Hi,
Colleagues could you say what is weight of Cyclone 4kw coaxial bike?
May be you know weight of bike from first page this post?
or
you know weight of bike "coaxial eeb kit".by Jamesavery22 » Apr 24 2019 2:04am
I would like full weight bike+battery.
Thanks![]()
I ask about it seller and here his answer:Tommm said:I think a regular long travel mtb frame is about 3kg, old mtb sytle coaxial frame is 4 or 4.5kg. Motor is 5kg, controller is 1kg. Rest is standard bike component. So coaxial bike with be ~7kg heavier than standard mtb without battery, and same weight without battery as a big e-mtb with a battery ~22kg.
The eeb frame is about 11-12kg without motor, so it will be ~30kg without battery. This is why with big hub+battery eeb bikes are about 55kg with moto wheels 65kg.
alexmaemur said:I ask about it seller and here his answer:Tommm said:I think a regular long travel mtb frame is about 3kg, old mtb sytle coaxial frame is 4 or 4.5kg. Motor is 5kg, controller is 1kg. Rest is standard bike component. So coaxial bike with be ~7kg heavier than standard mtb without battery, and same weight without battery as a big e-mtb with a battery ~22kg.
Elite bike without battery 26kg (simple fork 100mm and wheels 26,1)
battery 60v about 10
so 36kg
Frame Elite bike 14kg
Frame Enduro bike 18kg
so Enduro bike = 40kg
if you would like good fork + 1,5-2kg
if you would like 72v + 1kg
so 43kg
it is not strongly)) plus-minus
Tommm said:... I use it to commute for 3 months now, 44km every day...
alexmaemur said:Tommm said:... I use it to commute for 3 months now, 44km every day...
Thank you Tommm. It is very usefull notes. I haven't problem as you about stealth, but gravitation more and more when I go to 5 floor![]()
My calculation say - 35kg it is minimum, I must go to gym
Some people say bike can go up himself. It is't coaxial, it is cyclon 3000W.Tommm said:You should use the lift is possuble, park it diagonall, and lift the front to make it shorter. 5 floors is a lot, I sometimes push it up 2 floors a day at stations, it is slow and tiring.
If you have no choice, make the battery removable somehow and carry it seperately.
