larsb
I found info that a switch from star to delta connection for a motor gives a phase delay of 30 electrical degrees. I think it is explained by a different coils induction from the three coils connections in delta as compared to two coils connections in star.
If there's a good reference to this with explanation then please link it!
could this explain why original hall sensors are off for the Revolt RV120?
My thinking is:
Tuned setting for phase shift when optimized with an adaptto controller was 24 degrees, error margin to 30 is 6 degrees and the sensors were offset by some millimeter in the slots which could cause these 6 degrees. It roughly fits..
My guess halls for the RV120 are set neutral (as they are placed 120 degrees apart in the middle of the slots - no physical shift) and should be shifted 30 electrical degrees. That would be a really basic error if this is the case.
I will try the outside halls with 30(electrical degrees)/7(pole pairs)=4.3 degrees mechanical delayed hall location.
My thinking is:
