I returned the overchagred batteries. I took apart the rest and kept the LG cells for the future. I may sell them.
I got a good deal on a chinese lifepo4 pack (won it for $197 on an auction). 48v 15Ah. It came and of course it's a 16s, so it's a 52v pack that charges to 58v. I've read that these are good packs but the chargers are crap. I'll be replacing that ASAP.
This is my bike:
Its a craigslist wide-tire mountain bike. $40. Steel frame, walmart shock, upgraded seat, rim, pedals, and handlebars.
The kit was from a friend who recently upgraded her cargo ebike to a mid drive. It has a shengyi 48v 500w motor, contoller, lcd display, throttle, and brakes.
I got my battery, tested the voltage, and it was at 58v, so I assumed it was charged enough for a test. I twisted the wires together from the controller (the thickest ones that are obviously not for anything else)...
And...
Nothing.
I don't see an on-off switch, I played with the display, throttle, brakes, and checked and rechecked all of the wire connections. Either twising the wires together is not a stable enough connection, or this kit sensed that it was a 58v and won't accept it. There is no pedal assist hookup, I think it was cut off. I don't need PAS anyway. I tried the kill switch on the throttle too.
I want to use this battery. Maybe this controller won't accept it? It's a 48v peak 19a controller much similar to this one: https://lunacycle.com/replacement-controller-for-hub-motors/
I'm thinking maybe I could replace the controller? The hard part would be wiring. I'd have to cut the color-coded connectors off and figure things out myself.
For now I'll be charging the battery to make sure it's fully charged and balanced, soldering on connectors, and trying to figure out what is going on.
Help?
