vanilla ice
Minor legend
The little regen reading I've done here at ES has led me to believe that max C charge rate is the limiting factor to get a good amount of the braking/downhill power back in to the chemical batteries. I've also read about using resistors as a load to eliminate mechanical rear brakes. I'm sure it works well for its purpose but it seems a waste.
I was thinking feeding that power in to a small gen motor connected to a flywheel would be ideal for getting that 10% regen efficiency up to 50% or so. After braking or downhill runs, you could gradually feed the chem bats with the flywheel at a rate they could absorb the power well. I know it'd take some fancy clutch work, but it seems doable.
Obviously this is gonna be a lot easier in something big like an EV car compared with the lighter stuff like ebikes. But who knows, maybe a scaled down version could even work on a bike. I'm not really up on the latest and greatest flywheel tech. It seems pretty simple but I know it takes a lot of rpm to store a good amount of energy. Do you guys think the flywheel is a DIYable approach to regen?
