LewTwo
as soon as we get some propwash, flight line and energized dilithium crystals .....
Pushing back is hard on a bicycle, you need to be able to add the human power while sitting on the seat and balancing. Given you need to hang onto the handlebars to balance and steer that only leaves the legs. Hey I know, what about some sort of leg powered propulsion ? With moving pedals to put your feet on, you could rotate them in a cyclic motion, and with a chain you could transmit that power to the back wheel and push the bike forward!abdula said:use an engine that works similarly like the little cars for kids ...you push back the little car then it goes fast forward by it self....we can use this in ebike right ?
Hyena said:Pushing back is hard on a bicycle, you need to be able to add the human power while sitting on the seat and balancing. Given you need to hang onto the handlebars to balance and steer that only leaves the legs. Hey I know, what about some sort of leg powered propulsion ? With moving pedals to put your feet on, you could rotate them in a cyclic motion, and with a chain you could transmit that power to the back wheel and push the bike forward!abdula said:use an engine that works similarly like the little cars for kids ...you push back the little car then it goes fast forward by it self....we can use this in ebike right ?![]()
Raisedeyebrows said:How about a big rubber band you wind up like those nifty Balsa Wood airplanes? Twist it for a couple minutes and zoom, away you go on a solid 4 hours of high speed riding.
atarijedi said:No, the Stealth isn't worth $11k.
Sent from my SM-G930F using Tapatalk
abdula said:atarijedi said:No, the Stealth isn't worth $11k.
hi...can you give 2 reasons why it isn't worth $11k ?
thanks
rumme said:abdula said:atarijedi said:No, the Stealth isn't worth $11k.
thanks
Because this endless sphere member can build you a custom ebike from scratch that has stealth like performance for about 1/3rd the price. Is having the name STEALTH printed on your ebike, really worth a extra $7000 ?
https://www.youtube.com/watch?v=Xpxwou5SUuA&t=4s
abdula said:rumme said:abdula said:atarijedi said:No, the Stealth isn't worth $11k.
thanks
dont you think there is something suspicious about that build ? if he can build same and 10 times cheaper then he can replace that whole company and their whole team with only 1 person ? example: if bmw 2017 is $200k and another 1 person build same car for $10 bucks..........what you think is the different ?
different is ..quality and many other great things.
abdula said:hey man...thanks for reply...here is what i think about that video/ebike:
1. how much have you paid for the batteries ? $1000 or $2600 usd ?
2. it really dosnt look like a bicycle ..but looks like a electric motorcycle.
3. how much noise it makes on high speed ?
4. is it heavy ?
5. did you win any race against stealth bomber b52 ?
thanks in advance
thanks
atarijedi said:abdula said:atarijedi said:No, the Stealth isn't worth $11k.
thanks
1. They use low quality components, like the DNM forks and shocks. Don't be fooled that because they charge a high price, it means they are using quality, or the best components. They will put high quality components on it, but then the price will go even higher.
2. They use low cost components, yet their prices are super high, and labour cannot account for the differences in prices, so their markup has to be massive. For everything except the battery and controller, you could spend less than $3000 building it yourself. With a better battery than they offer, and with a more featureful controller, you would still only hit maybe $5000 at most.
I also don't like how they have a fenderless front wheel, along with an unprotected controller. That is a sloppy design in my opinion.
Like others have said, you can DIY a much better bike, for a much lower price. Plus you will learn a lot in the process, and be able to fix and/or upgrade your bike at any time. My bike, in the end, will probably have cost under $6500CAD ($5200USD), depending on the battery I decide to build for it.
Hey, how much work did you put in to build your bike? I might want to buy it from you for $3000, if it is indeed just as good?rumme said:I'm in this ebike for around $3000 . It will keep up with the Stealth as far as speed .
GPS told me I hit 55 mph a few weeks ago and I still had throttle left to give it, but backed off. I had the controller programmed so now it will only hit top speed of around 45 mph,which is plenty for me.
Battery is 72 volt- 28.4 AHS - Samsung cells. Has hydraulic disc brakes , adjustable front/rear shocks , tubeless tires , nice kickstand ferro fluid in the motor , and I upgraded the wiring to 8 gauge . I'm using a Lyen controller and running sensorless. IMHO, no way in hell the Stealth bomber is worth 7-8 grand more then my ebike.
I think the only things that I disliked was the turning radius of the front wheel . Its much less then a normal bicycle and I guess a stealth bomber may have the same issue. With this type of ebike, you have to really lean into tight turns, kinda like a motorcycle. It only has 1 gear, and that gear is to low to really pedal if the bike breaks down.
MX Engineer said:Hey, how much work did you put in to build your bike? I might want to buy it from you for $3000, if it is indeed just as good?rumme said:I'm in this ebike for around $3000 . It will keep up with the Stealth as far as speed .
Or, if you are not selling, please post your list of parts so that others could build the same.
I think I remember your post and that member. His price was about $9K, not $3K.rumme said:If you look back on this thread, I posted info about a member on here, that builds these or can sell you all the parts individually, so you can assemble it. You may want to contact him. I did not plan on selling this , but thanks for the offer.
MX Engineer said:I think I remember your post and that member. His price was about $9K, not $3K.rumme said:If you look back on this thread, I posted info about a member on here, that builds these or can sell you all the parts individually, so you can assemble it. You may want to contact him. I did not plan on selling this , but thanks for the offer.
2old said:S, any updates on your rides? Also, can you ride motorcycle trails without a green sticker?
