cwah
amazing
Frakentrike said:With all the CNC milling and 3D printing, is that what you do for a living or is it just perfection in your hobby!
Frakentrike said:I love your new suspension - Is bump steer and brake steer a lot worse now that the king pin axis doesn't hit the ground where the tire contacts the ground? Or do the new larger diameter wheels now bring the contact patch much closer to the king pin axis again? (hard to tell from the photos)
adam333 said:On the 16" KMX wheels, the bike is really stable at low or high speed. But yes, on those fat 22.5" tire, I have a non zero scrub radius. The bike is definitively harder to steer and less stable at high speed. It also become important to balance the wheels.
Shane07 said:Hi! What did you use to mount the cycle analyst? I'm looking for a solution on my kmx recumbent.
regards Shane
regards Shane
adam333 said:No, the flagpole is not mandatory, but the trike is so low that I almost got me killed 3 time from cars that "didn't saw me".
Since I have the flagpole, It is no longer an issue.
