Hey folks, i just came back from a ride with some friends.
Its so much fun to ride that powerfull middrife in fall, with all the leafs... spinning all the time when hitting the throttle
Nice work on that axle Mike!
i like the step from 12mm to 15mm, that should hold a lot more of force.
Im Also very interessted in the new 40T 219Sproket.
What do you think about a singlespeed setup at 4-5Kw with only two reductions? do you think the Belt with the 25T Pully can handle it? so first reduction would be 1:3.6 and the second reduction would be from the 40T 219 direct to the rear wheel with a big 219 Sproket. Possible?
I want do my next build without pedals...
im asking this because since i changed my reduction on the Small block kit, it seems like it can handle 3000W reliable, nothing streches or flex, no more beltskipping, even at 3000W full power starts... i have the "not so strong"-axle in the jackshaft, and it did not bend for now (after 1500Km driving with the new, lower reduction).
with the lower reduction, i have now 40 Km/h in the slowest gear, and still more than enough torque to climb, wheele, spin etc..
so the last 3 or 4 rides, i only used the bike in this one, slowest gear... only on street i changed a few times the gears, but for the offroad-parts i dont have to switch gears anymore :wink:
Here some fotos of the new Bike, installed a new SRAMX7 dereilleur and Cassette and tested it...
workes great, much power, same as the DH-Bikes... the motor was moving a little bit to the right side after 3000W-start tests. Its the same setup like on my DH-Bike at 75V 30-40Amps. only thing to do now, is to build a third fixation of the Kit on the upper tube of the frame to hold the Jackshaft strong in place.
... and then i will give it away... its a Medium Frame and i would need a large one
but it was much fun to build this bike anyway.
Here are the 25T-Drivers Mike send me some time ago, i used to upgrade all Bikes with 2000W+ with those.
look how big they are
... now i wandered from the subject, in first place i wanted to ask you if the belt and Pullys would handle a 2 stage reduction direct to the rear wheel, as mentioned above.
... i place the other fotos and stuff in my thread, sorry for fotobombing yours
