Alan B said:
Splicing at the leads as Lebowski suggests is another approach worthy of consideration.
you tell me NOW!
i thought of that as well, and wanted to do it. but as there was a lot of solder i was afraid that if could drip inside and cause some shorts, so i did it the hard way. i guess it will be as good as new when i'm done.
the boards are cleaned, the standoffs are cleaned as well and fit inside the holes again. i will solder the standoffs first on the FET board first, and then add the second board.
but first i have to finish another bike. i just can't add a new CA with all the leads dangling out of it. i MUST open it and remove all unused wires and shorten the remaining ones to the correct length. but after that it's a clean job. takes some time though.
