aCeMadMod
hi can show pic of what the pazza look like , i may like to take a bite ,, great work hope you can sell the broad soon,
thank you
thank you
they need a special setup for the mac as well.
ok. thanks for confirmation. i ordered 150B. this will give a little headroom in case the MAC starts to work properly with the controller *ggg*Lebowski said:Nope sensors must be bi-directional as all motor currents are AC...
Animalector said:some renders of the new layout. Upgrades are mounting bolts for driver board,no need for copper posts, more space for Caps,
At some stage I will re-do the CPU board, and use cheaper more common regulators and add temperature sensors,
Mine was always form things like the driver latching or the 5v supply dipping. It was things that were my own fault.Lebowski said:Izeman but also Arlo1 had some funny things going on where the chip reset itself during the FOC measurement.
I aim for 5.2v spec says 5.5v max I have the crx at 5.64v to the brain as i need ~ a 100k resistor to set my lm317 down a touch moreizeman said:the dc/dc converter i installed is a 3A (!!) type. so it should be able to hold voltage quite nicely?!
of course i can't say how stable it is. what is the top most voltage i should set it to? maybe 5.1 or 5.2V? so if it ditched it may not go down to 4.7V.
It is not only the amps it can deliver, it is also the speed with which it responds to input supply or load changes....izeman said:the dc/dc converter i installed is a 3A (!!) type. so it should be able to hold voltage quite nicely?!
so for testing it may be a good idea to feed 5v from a battery? it shouldn't sag at at 200mA.Lebowski said:It is not only the amps it can deliver, it is also the speed with which it responds to input supply or load changes....izeman said:the dc/dc converter i installed is a 3A (!!) type. so it should be able to hold voltage quite nicely?!
