def,
I may show up and insist eventually - but these were offers that I don't think take it out of the "you paid for it" range, I've picked up a few things from you (what not to do in philly snow) and I'm sure others have too... your putting junk (not like AmberWolf but low end bits) to good use and it's very inspiring to the other shade trees amongst us... so imho, tossing you parts I would / will not be using benefits everyone and comeon man... it's not like I'm in Cali, were nearly neighbors
Seeing you got another 250w currie running with your 7T drive, and seeing your rather "lack of impressedness" {sorry had to south philly} until 15mph but then reasonable performance until 22mph... I'm a tad worried, I know you indicate that even the guy who fried your setup did no damage on this build up but...
If my understanding is right (who knows) - your maximum power should be at 1/2 of no load speed, I would wager we can really tune the performance of the setup if you can get a reading of no load RPM... I know you don't have an RPM meter right, but you work in a shop so use a timing light to clock it? In either case, if you can get no load of the motor... I may be able to suggest a different gearing to get you better performance and locate the "power" band where you want it (wherever that may be).
Another thing that I find concerning, unless you have it geared so poorly that the motor is struggling under load until 15mph is reached (I don't know your reduction ratio so I can't guess at motor RPM under load) so I'm wondering if maybe your controller isn't doing some form of "soft start" type thing?
What is the output shaft size on your motors, 8mm, 3/8"? I have spares of many BLDC motors with good bits which I won't be using but would give you 18-20% more efficiency over a brushed DC motor and also much more power if you wanted it (or a huge buffer zone in output power)... gwhy has PCBs for adding the halls now so it's fairly Piece of Cake to get an infineon working on a Tower Pro or Turnigy and running with any voltage pack you require to match your power and speed needs.
In either case - the offers stand, I even have some LiPo you could have (sorry I need some A123 cells myself right now, 3 to be specific) which isn't puffed but has seen about 400 cycles at 2-5C discharge and still holds 4.8 AH per 5AH block with 4.16v cutout HVC and 3.2v LVC (so same as the first week after break in) - this pack has been charged as 6S in parallel at 1/2 C maximum rate immediately after using...
Well... as always - your welcome to pick the parts bins here, really you would kinda be doing me a favor!
Oh yea - if you were interested I have a spare 3spd freehub SRF3 internal hub laced into a nice 20" rim which would work with one of Gary Goodrums adapters (or your own) to add a nice large rear drive sprocket - keep the straight chainline and freewheeling of both motor and pedals but isolated at the rear while adding 3 speeds (1.33x, 1x anx .75x) for both pedal through and motor through - really extending your speed range while optimizing efficiency. I'd be happy to give it freely but if you insisted you could pay me what I paid (49.95 for the whole shebang with small parts, 16t cog and shifter).
Just thinking if you wanted to do a nice BMXish, low weight RC style build - the 3spd internal rear should be good for up to 5kw on a 20" rim... personally I'm approaching 2600w input power and approx 2300w output maximum on my latest test setup with a 60.00 turnigy motor running 6S LiPo.
Glad to see the iron steed is back in service again!
Regards,
Mike
PS: What's your day like tommorow - if the rain holds, I'll be riding to the city for the day just to hang out and catch up with some friends in South and around Rittenhouse... maybe we can catch up for a coffee or a race? We could find some bike cops to fuk wid
hehe
