OnebigChicken
🧲 New user
Hello!
Id appreciate any insight, prefacing this by confessing that I'm very ignorant about bike/electrical maintenance and repair so this might be a dumb question or have an obvious solution/cause that I don't realise.
Issue: the back and front light do not turn on, screen shows lights activated but no power supplied, I don't know how to access cables to check if they've come unplugged, lights did work previously. I have to ride back from uni at 6 on an 80km/h road so it's pretty dark and scary with my torch
Bike: Smart Motion X city neo unmodified from purchase, it's pedal assistance and throttled up to 25km, everything else works swimmingly
Odometer: less than 1000kms, it's out of warranty due to time passing
Issue circumstances: it seems to have happened during or a bit before shipping as a family member has shipped it interstate, the shipping and having it moved around is why I suspect it might of come loose, the cable is also pretty lax and the plug connecting the front light comes undone easily and needs to be taped together (I took the tape off for the picture), I can't rule out other potential causes though
Parts: The cables connecting the front light are 2 pin julets male/female but am unsure as to everything else because I can't access them
Link to bike (there is a manual nut it doesn't help)
Link to light extension cable:
Goals:
1. To find out if I should be trying to access the inner cables and if this will help?/how to do that?
2. Any other troubleshooting ideas?
Thanks
higher def images from the first image ↓
Goals:
Thanks
