Skaiwerd said:
Gman1971
Nice. Are you drifting there? Prob not. Just enough blur to the picture to make it look that way. Do you pedal sometimes or mostly always? You have front suspension right, which would help with leaning into corners and normal road bumps, alowing for higher speeds. Does the rear tire ever break free? I'm getting that on bumps, my brooks sattle with springs needs a shock absorber, to reduce bounce. I've looked at the sport bike (motorcycle) steerering stabilizers to use but don't know if a shock to a seat is feasible. Something packed into the springs could work I think.
Thanks.
No, not there, we were just coasting to a stop when picture was taken.... I rarely drift onroad as I don't want to roast the tires... in the past I've done drifting on the wet (or snow) without much of a problem... but its an art, otherwise you can roll the trike.
See here for me drifting the trike...
https://www.youtube.com/watch?v=HASmlukfo9Q
I do have a front suspension with air shocks, but no rear, and the ride is so nice it rivals my car. Most of the weight on my trikes is also over the front wheels too, so the rear wheel rarely bounces off the ground unless its a very big pothole. The front suspension makes the trike also considerably wider so there is less of a need to lean into the turns.
A brooks saddle probably wont work on the KMX trike... so I am not sure how that would work, but yeah adding something to rub might help. Someone a while back suggested the idea of using an elastomer block on the seat mounting point, but on the KMX that might not work b/c the seat is also attached/bolted to the rear frame. Truth is tho, that the times in which I think I needed a rear suspension is maybe once a week, at worst; but the times I am glad I have a front suspension is like 1000 times per ride, or more...
I've ridden the trike at 65 mph without steering dampers, and the thing just drives like its on rails, BUT... you need to properly align the front wheels, b/c if you don't, it will feel super-unstable at high speeds.
I pedal mostly when riding weekend adventures with my family, the rest of the time is dummy pedaling at 30-35 mph...
G.
